Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Ok, thank you for the suggestions guys. I forgot to mention that I have a 5v regulator plugged into Pixhawk main out 8 and the motors 1, 2, and 4 are opto ESCs that all work fine. The yaw servo seems to be energized but I wasn't sure about the APM operation. Based upon your suggestions, it may be the laggy feel I am experiencing.
This is my first tricopter, which is also a tilt wing, called a CL-84 from Hobby King. I flew it fine using SimonK ESCs and the stock controller allowed for yaw stick to move the yaw servo. While I wait for Tridge to make some special tilt rotor code for the CL-84 transition servo, I thought it would be cool to try Arducopter v3.3.3 and have it hover in place like a real autonomous vehicle. We'll see what happens...
You guys were correct. I re-tested and I do have yaw control, but it is real sluggish. I found the RATE_YAW_FILT parameter and changed it from 5 to 20. However, the other two parameters elude me. Could the names be different in v3.3.3?
RAT_YAW_FILT = 20
SLEW_YAW = 18000
Y_MAX = 100000
try searching for "slew" and something related to acceleration over Y axes.
setting those will give you the "manual" like yaw control.
also, it helps to properly set servo endpoints to something like 1100-1900, defaults are really minimal.
do not forget your servo midpoint, i find that setting it slightly off center to counter natural yaw helps, but since it is a "plane" not sure how it will affect the fixed wing mode.
That's much better. I found the params in v3.3.3 as follows and set them to your values. I have yaw control now. Thanks for the tips!
RATE_YAW_FILT = 20
ATC_SLEW_YAW = 18000
ATC_ACCEL_Y_MAX = 100000
Could you please point out a model, make of radio you referring to, or url to one on Ebay, so I can get a ideal of one your talking about.
thanks for the info.
hi all. please help.
i just build new quad 250 pixhawk and tx gx7 JR, i can fly good with mode stabilze but i can't control and take off or control with alt hold mode. because the mode alt hold only work with thorttle, picth and roll and yaw not working.
can someone help me fix this ?
Better if you can share
My CL-84 VTOL is hovering quite nicely in some wind now after adjusting some PIDs. This was just a test while I wait for Tridge to release some new Arduplane code for the CL-84 tiltwing. I also updated my Tarot 680 Pro hexacopter from Copter v3.1.4 to v3.3.3 and after re-calibrating the ACCs and GPS, it flies perfectly!
CL84 with APM Copter Test 2 from Gregory Covey on Vimeo.
a log, easier to help
