Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
eCalc, at least for data @hover, is way off. I don't know what they did, but comparing their current version to that of earlier ones, anyone trying to use it for a build right now will not be getting accurate estimates
When I set up my latest quadcopter a few months ago, eCalc estimated for 13x5.5 props, KDE 2814xf-515 motors and AUW of 2240g, @hover throttle position would be <45% IIRC which is pretty close to reality. Now it says with the exact same configuration except 15x5.5 props @hover throttle position is 55% !!!
That is absurdly wrong.
On my Y6 eCalc says hover current draw is 38A, when actual is <28A.
I've contacted eCalc to review their new version because right now it is completely unreliable.
3.80v per cel. Means that your charger was in a storage mode.
It is the ideal voltage to store LIPO battery's for a long time, but for flight your cell voltage should be at 4.20v per cell.
The best way to charge is by using the Balance Charge mode, which Charges.al Cells to 4.20v
It should never go over this voltage !
Ok forget it, you started with this value of 3.80v, so forget my comment.
Erik
Hi Erik,
Thx for your answer.I wasn't clear enough, when I measured my battery after the flight it was 3.80V per cell. The battery was fully charged (4S 16.8V, 4.20 per cell) when I started my flight.
Hi Igor,
Please show us your log file.
Unfortunately I can't.
All my logs are gone, wtf?
It seems that my complete logs folder is wiped out. No logs whatsoever.
I do have a backup of my old logs on my server, but I didn't copied the latest files.
Damn!
How is it possible? Is it MP fault?
Now I will never know what happened... :-(
I have had the same experience twice, but I got the logs. When examine them I saw that the fc tried to correct but the motor did not respond, so I thougt motor or esc failure? Changed motor but after 2 more flights the same thing happens, so now I have ordered new esc to see if that will fix the problem? It was Engine 2 on my quad that did not respond to the fc so it went to the left and down...
Randy,
Do you think that the mode switch channel remapping will be available for PixHawk in the final release? I am waiting on this feature for my Phantom Clone with a PixHawk FC.
Joe
No, I don't think it's going to make AC3.3. I could probably do it without too much trouble, but we've pretty much reached a "feature complete" stage and no feature additions are going in. Just cleaning up any remaining bugs.
And I still have a fair amount of work to do just getting Heli working right again.
Roger that.
Thanks for the update. We appreciate all the time the Dev team puts into this project.
Joe
Hi
Some pages of the website say that the firmware to control a CoaxCopter is available and others not?
what about it?
What electronic card should I use for a CoaxCopter: PX4 or PixHawk?
