Crash analysis APM2.6 decline after flying high
A couple of days my quad crashed, because I'm kind of new to Arducopter I would like you to review my reasoning (log file is attached to this post).
The flight & crash
After having flown for some minutes on a mountain hill in Loiter (+- 10th quad flight), I decided to increase the height of my F450, 2212, 9443 props, to record a nice shot with my attached action cam. After this shot I lowered the height of the quad, and when it reached about 10M above the hill's surface I gave full throttle. Unfortunately, the Quad didn't stop declining (but remained 'horizontal') but crashed and rolled down for 10 meters or so.
The log analysis
3691311021?profile=original1. moment of impact; from the Yaw and Roll parameter I found out that the moment of impact is 13895.
2. the power send to the motors, from CH1-4 I found out that motor 3 is running at full throttle (and that it's waveform is much more 'digital' compared to the waveforms of the other ESC channels?).
- because the quad remained flat (didn't flip), the prop was still on the motor.
- because the quad remained flat and CH3 was on full throttle I ASSUME that the other motors were not able to run at a higher throttle (stability issues)
SO, I expect that my COG is not in the center of the quad frame (due to the off center placed action cam and the GPS) because of the fact that CH3 has to work harder (but not everywhere in flight! strange?). Furthermore I expect that my quad is a bit underpowered because CH3 is not able to keep the quad in the horizontal plane when other motors would be spinning (only in this situation!). Do you AGREE?
3. the ANGBST parameter is <-1000 (MINUS!) during the decline, what is the reason for this?
Furhtermore, I've done this shot 10 more times, but the quad didn't crash, what could be the reason for this (same hardware config)? (Wind?) Although I made one hard landing during an earlier flight when I came from 50 meters high (I think that this cause was the same as this crash cause).
Solution:
Attach bigger props to my quad, to increase the thrust from 650 gram per motor to 1050 gram per motor (as the quad AOW is 1.7 kilo!
Thanks a lot!
CrashLog [7904].log
  • While it is in VRS state a bit of forward stick should clear the vortex and the wobbling is indeed a sign. Without seeing your rig it is difficult to comment on CH3 as it is quite possible that your cog is the reason. If not excessive that should not be a problem. Remember that it is not uncommon to see 1 motor being at full throttle while the 3 others are near to maintain attitude. Cog can be a reason but even a slight breeze at a certain direction can have this effect while on full throttle. Your quad stayed more or less level during the VRS so i see no problem there.
  • Thank you for your comment! After doing some research this seems to be the cause of the crash (the quad was 'wobbling' during it's descent and didn't respond on it's throttle).
    What could be the reason that one of the motors (CH3) was on full throttle?
    Micha said:
    Vortex ring state maybe? I am seeing some i2c errors, reroute your mag cable and there is a problem with current sensing but neighter should be the reason. Could still be VRS. Was there any wind at all?
  • Vortex ring state maybe? I am seeing some i2c errors, reroute your mag cable and there is a problem with current sensing but neighter should be the reason. Could still be VRS. Was there any wind at all?
DIY Robocars via Twitter
RT @breadcentric: Evo is coming to town. If you have an #AWS #DeepRacer, you can purchase an extension pack! https://t.co/w60JwI98Hp #Machi…
57 minutes ago
https://t.co/bzpbxytpsv
22 hours ago
DIY Drones via Twitter
RT @chr1sa: My talk on PX4 and FAA certification is coming up at 1:45 PST today on the PX4 Dev Summit livestream. Includes some cool new st…
Jul 7
RT @seesharp: I'm tuned into the PX4 / Dronecode free live conference. Great stuff. Microsoft AirSim talk in 10 minutes. https://t.co/0zbZ2…
Jul 6
RT @masato_ka: 距離センサを3つとESP32を付けたラジコンカーをDonkeyCarライクにNNで自動走行。3層FC極小モデルをTensorFlow Lite for microcontrollerで動かしてる。機体は借り物でRumiCarって言います。Tenso…
Jul 5
RT @SmallpixelCar: My car was able to go all the way autonomously until the crosswalk. It was only 100 yards from the target. What should b…
Jul 4
Liam left a comment on Agricultural UAVs
"Hi
I'm Liam from T-MOTOR. I would like to reach out to see if there is any possibility for us to work together.
We are a propulsion system manufacturer who offers motors, propellers and ESCs for all kinds of drone applications which vary from secur…"
RT @SmallpixelCar: Smart move. The car used the shadow to guide it through the bridge. This was never in the training samples. But it learn…
RT @SmallpixelCar: Getting closer to the target. Single camera. Untrained road. https://t.co/Wsr7RwDamj
Jun 29
Richard Cox left a comment on Australia
"Anyone in the DIYDRONES Australian subgroup based in Alice Springs, NT?
I am experimenting with Ardupilot (standard Arduplane), Pixhawk 4 FC in a 4-ch
RC "AXN Floater Jet" foamy plane..."
Jun 29
Omar Sykes left a comment on Australia
"Hi everyone, I am looking for someone who is good at drone building, repair and software in Adelaide. Please give me a call on 0477 319 219."
Jun 29
RT @RoboticMasters: #donkeycar https://t.co/czuLoVRcA4
Jun 29
https://t.co/DKQbNTbz0g
Jun 29
RT @RoboticMasters: Donkey car, car car car car car car; Donkey car, car car car car car car; Donkey Car. Anyone like our tiny tiny donkey…
Jun 29
RT @SmallpixelCar: After improving DBSCAN speed, I can get 11 frame per second on @NVIDIAEmbedded Jerson Xavier MAXN mode and the autonomou…
Jun 26
RT @Heavy02011: Join us at next Virtual Race League: ⁦@diyrobocars⁩ Race #4 - Parking Lot Nerds, August 1st https://t.co/5KUpu7VGaH
Jun 25
