Question to a developer, why not make it so that when a GPS signal is lost in RTL mode transition control mode stabilize?
Because of the loss of GPS signal recently flew a quadrocopter. After enabling RTL for the lost GPS copter gained altitude of 200 m and left in an unknown direction.
    The APM try to make its best to circumvent difficult hardware situations, and version 3.0 will add a couple enhancements here and some checks before arming, but obviously it is often impossible to fix a hardware problem with software during flight. Copters need strong mechanical and electronic user checks before flying and rigorous parts changes periodically (in our case mainly motor ball bearings).
    Failsafe and RTL must be considered the last resort.
    Anyway If you have radio control it is easy to change the mode back.
    Without radio control we need to rely on the APM and in this case it is mandatory to decide a failsafe action as soon as possible, depending on the failsafe source and available sensors the safest action is decided, with an emphasis on ground people safety. Getting back the copter become less important in situations where radio link + GPS are lost.
    We can't wait when a failsafe do occur. Generally the more you wait, the more chances to crash.
    Version 3.1 should have another radical failsafe option, but that's another story. (it's not self destruction :)
    Olivier.
  • Thank you all for your responses and rapid response to emerging issues.
    Thanks to the developers for your work.
    We will test the version 3.0
    I did review the code and you are right, we check only if we have a home position when switching to RTL.
    This mean that if there was a GPS fix at take off (home position was stored) and later the GPS fix is lost, you can have a flyaway when asking for RTL.
    This will be fixed in version 3.0 with a GPS failsafe feature.
    Thanks for pointing this problem and please report if you still have this problem when version 3.0 will be out.
    Olivier
    I've started a developer discussion to check for a couple radio failsafe and RTL things in the code.
    Olivier
DIY Robocars via Twitter
21 hours ago
RT @_JonMyer: 🏎 We need your help in naming my #AWS DeepRacer Underground Track 🏎 @davidfsmith's track is going to be referred to as 𝗔𝗪𝗦 𝗗…
Thursday
RT @gclue_akira: 仕事もおわったし、電脳化にとらい #マリオカートハック https://t.co/4IU90hCLgm
Thursday
This is the hashtag to follow all the people in Japan who are hacking the new Nintendo Mario Kart with the real AR… https://twitter.com/i/web/status/1319281354664677376
Thursday
RT @gclue_akira: @chr1sa @diyrobocars jupyter mario https://t.co/P0oHdjlCRq
Thursday
RT @_JonMyer: 🚨Our 1st AWS DeepRacer Community Race is Underway on http://twitch.tv/aws 🚨 Join us to find out which member of your commu…
Tuesday
Monday
RT @BackyardRobotcs: After an admittedly long wait, the new Tinymovr R3.3 motor controller is now available https://tinymovr.com 🥳
Monday
RT @_JonMyer: 🏎 1 hr left before the #AWS #DeepRacer Community 🏎 Top 5 Race tomorrow LIVE on Twitch 1st Place = $50 Amazon GC or AWS Credit…
Monday
Oct 16
Oct 15
Oct 14
RT @davidfsmith: Race virtually with The AWS DeepRacer Community Race and then join us on the track to see how your times compare on the ph…
Oct 14
Oct 14
Hiroki Tanaka liked Hiroki Tanaka's profile
Oct 13
RT @breadcentric: It's now!
Oct 13
