Anyone know the current status
of this command?  I noticed in
the past there were a few bugs.
When I try using in the sim,
it seems to have no effect at all,
or (once) it had an erratic effect...
Thanks!
--David
More -- when i set do_control_speed to 0,1,1 (airspeed, 1 m/s, 1% throt), and had it fly
to a waypoint at the same altitude it started at, it did fine until it started to stall
(ie, it glided with no throt).  Then it went nuts trying to right itself.
I should note I have Alt_Cntl_Alg set to 1, so that I can dive steeply.
My guess is it is programmed to not let itself stall and crash.  Given the
various commands I've given it, it's going a bit nuts...
I'm going to try setting a series of way points, each at a lower altitude,
set at horizontal distances that should be no problem to make (throttle off),
given the glide ratio of the RC plane.  Hopefully I'll never hit stall conditions,
and the do_control_speed command won't wig out.
More later,
--David
I discovered this while playing with the HIL Sim, I put it in the wiki here under basic commands: (http://code.google.com/p/ardupilot-mega/wiki/MPWaypoint)
All DO_xxx commands currently need a dummy waypoint placed after the command
eg:
WAYPOINT_1
DO_SET_HOME
WAYPOINT_2
Home will be set at WAYPOINT_1 but will not work if WAYPOINT_2 is not there.
I've got waypoints after the Do_Chg_Spd command.  But they
have lat/long data.  When you say "dummy" do you mean
empty waypoints (all fields set to 0)?
I could only get my do commands to work if there was a waypoint after the do command, but the waypoint wasn't going to be used in my case. I did add it with all fields set to 0.
I didn't try the Chg_Spd command though, just the Set_Servo and Set_Home
