Hello pilots! I am new and want to build my first quad copter, but I am not sure about the ESC, Motor, Propeller on my part list. I also do not know which battery pack and battery charger I need to fly between 10 and 20 minutes with my setup. Please give me advise about the parts, if you think there is a better alternative or if I forgot a part. Thank you!!
MultiWii PRO 2.0 Flight Controllerhttp://witespyquad.gostorego.com/flight-controllers/multiwii-pro-2-0-flight-controller-200.html
Q450 Glass Fiber Quadcopter Frame 450mm - Integrated PCB Version http://www.hobbyking.com/hobbyking/...opter_Frame_450mm_Integrated_PCB_Version.html
NTM Prop Drive 28-26 1350kV * 4
http://www.hobbyking.com/hobbyking/store/__21479__NTM_Prop_Drive_28_26_1350KV_302W.html
Slow Fly Electric Prop 8045R * 4
http://www.hobbyking.com/hobbyking/...ctric_Prop_8045R_4_pc_Green_RH_Rotation_.html
Slow Fly Electric Prop 8045SF * 4
http://www.hobbyking.com/hobbyking/store/__22438__Slow_Fly_Electric_Prop_8045SF_4_pc_.html
TURNIGY Plush 25amp Speed Controller * 4
http://www.hobbyking.com/hobbyking/store/__2163__TURNIGY_Plush_25amp_Speed_Controller.html
TURNIGY BESC Programming Card
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=2169
PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC)http://www.hobbyking.com/hobbyking/store/__68__PolyMax_3_5mm_Gold_C...
Power Harness
Lipo battery
Battery charger
Hobbyking 2-8S Cell Checker with Low Voltage Alarm
http://www.hobbyking.com/hobbyking/...2_8S_Cell_Checker_with_Low_Voltage_Alarm.html
Turnigy 9X 9Ch Transmitter w/ Module & 8ch Receiver (Mode 2) (v2 Firmware) http://www.hobbyking.com/hobbyking/..._Module_8ch_Receiver_Mode_2_v2_Firmware_.html
Ok, then I will go for the Turnigy nano-tech 4500mah 3S 35~70C. I have a Zippy rc plane, and had only bad experience with it, will never buy Zippy products anymore haha
Hey just added you as a friend, would love to talk to you about this build and see how it went. Getting ready to build one myself and want to ask if you would suggest anything different in your list. Shoot me a Personal message if you could when you get a chance. Thanks.
Hi Shahin,
How did this assembly go? Faced any issues. Is there any significant change in the list you suggested?
I am asking because I am interested to build a similar frame.
Hi Mohamed,
There was one drawback. The multiwii pro 2.0 was a disaster and GPS did not work no matter what I did. I bought the DJI Naza V2 with all the other parts the same as the list above and it was perfect! It flies perfect and I LOVE it. Two video's of the new system flying:
https://www.youtube.com/watch?v=wwZ62udFcVs
and
https://www.youtube.com/watch?v=CcWxnxagADE
Good luck and have fun :D
This is the new parts list:
Turnigy nano-tech 4500mah 3S 35~70C Lipo Pack 2,00 $36,35
Turnigy Accucel-6 50W 6A Balancer/Charger w/ Accessories 1,00 $22,99
Nylon XT60 Connectors Male/Female (5 pairs) GENUINE 1,00 $3,29
Turnigy 4mm Heat Shrink Tube - RED (1mtr) 1,00 $0,35
Turnigy 4mm Heat Shrink Tube - BLACK (1mtr) 1,00 $0,35
PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC) 1,00 $1,69
Q450 Glass Fiber Quadcopter Frame 450mm - Integrated PCB Version 2,00 $12,53
TURNIGY Plush 30amp Speed Controller 4,00 $12,53
TURNIGY BESC Programming Card 1,00 $6,91
MT2213-935KV MultiStar Motor and Propeller Combo 10x4.5 CW/CCW 4,00 $14,63
Turnigy 9X 9Ch Transmitter w/ Module & 8ch Receiver (Mode 2) (v2 Firmware) 1,00 $53,82
Hobbyking 60w Power Supply 1,00 $9,99
HobbyKing™ Lipoly Low Voltage Alarm (2s~4s)
Don't use this low voltage alarm from HK. It caused my quadcopter to crash because the battery alarm did not turn on when the battery was almost empty.
I bought one from somewhere else where you could setup your own minimum voltage.
1,00 $2,15
Express Mail Service to NETHERLANDS (Lipo) 5000g 1,00 $62,11
Turnigy nano-tech 4500mah 3S 35~70C Lipo Pack (EU Warehouse) 1,00 $41,23
Registered (Tracking) Parcel within Netherlands 1,00 $6,21
Turnigy 9X LCD Backlight Kit - White (DIY) 1,00 $7,98
International (Registered) Air Mail 0 - 100g No Lipo 1,00 $3,99
Turnigy nano-tech 2500mAh 3S1P 5~10C Transmitter Lipo Pack (EU Warehouse) 1,00 $14,83
DJI-NAZA-PLUS-GPS-V2 1,00 €225,00
Thanks for the reply. How much was the flight time when fully loaded, and fully charged?
I have another question. Have you tried to fly a good smaller quadrotor size?
Almost 15 minutes. It depends on how fast I fly, the faster I fly, the faster the battery is drained. I've not flown any smaller quadcopters yet.
