Hi everyone, here is the new version of DroneFlight with new options.
can someone test this App and the autopilot function ????
https://itunes.apple.com/fr/app/dronefl … 29537?mt=8
DroneFlight:
Drone Flight is a universal app for iPhone, iPad and iPod touch to control your AR.Drone. It is compatible with the AR.Drone 1 and 2 of Parrot.
With this App you can create a flight path with several checkpoints/waypoints. In the autopilot mode the drone will follow the path created by the app. in the settings menu you can you can choose if the drone can stop at checkpoint or not etc.
The GPS autopilot function only works with the AR.Drone 2.0 and the flight recorder module (or another USB GPS)
The GPS works with the 2.3.3 firmware and several drivers (just go to the update menu)
- Support for the 60beat gamepad
- Autopilot function (with the GPS module)
- Add/move checkpoints on your flight plan.
- Define checkpoints altitude and speed.
- Take photo and video
- Use the 4 inch display of the iphone 5.
- full NavData
- lateral speed, altitude, orientation
- full NMEA raw data
- GPRMC, GPGLL & GPGGA
- latitude, longitude, satellites used, HDOP ...
to use the autopilot function:
1. The first time, upgrade the firmware of your drone in the update menu.
2. Go to the checkpoints menu
3. Create the flight plan with several checkpoints
4. Go to the control menu
5. and press the autopilot button after take off
Hello, can you tell me if I can go beyond the WiFi if so everything seems really great.
Thank you
