i got my easystar ready to fly kit today and i was going to change the motor and other stuff but it appears to be glued together . does anyone know if it is infact glued or is it just stuck. eg. can i pull it a part or is there a trick to get it apart. i dont want to try anything till i get an opinion.
thanks
It's glued but not hard to pull out. Just cut along the seam of the foam over the entire power pylon and gently pry the sides apart. The motor should be pretty easy to extract.
thanks i got it appart. some parts were tricky but its not glued they used double sided tape to hold the plane together . once you get it started it comes apart a little easier. engine is held in with double sided tape aswell.
