100KM
Electric Replacement for Mini Mugin 2.6m?
Hi all
I'm about to take the plunge on a Mini Mugin 2.6m from FPVModel. I really prefer it to be electric, so I need some suggestions what to replace the motor with.
It comes with a DLE30 motor swinging a 19" prop. The factory (after my insistence that it should be electric) suggests:
Battery: 2W 6-8S
Motor: 6350 kv 380
ESC: 80-100A
propeller: 20X10
I was thinking a HobbyKing Rotomax 1.4 which is rated 2.7 Watt and 228kv.
Any wisdom much appreciated.
  • 100KM
    I'm using an E-Flite Power 160. Initially I had an EMax, which I'll never support again - magnets came off in flight repeatedly and after sales service is non existing.
    It's done many, many flights since. Going strong.
    3702057272?profile=original3702057349?profile=original
    • Great :-D How many cameras/sensors you can fit in it and how log is the flight with current power setup?
      • 100KM
        I've had 3 cameras onboard once, with just one I get just about 2 hours.
        • Three is more than enough. With 2 hours flight at 300m alt. may be can cover up to 600ha. area in one mission.
          • 100KM
            600ha is exactly right! That's what I can achieve at 100m at 80kph.
            • If at 100m alt. and your cameras is 20MP or high quality capability that's really impressive output can be achived (Orthophoto & DSM). If you can have a test with advance sensors like NRGB cameras (like satellite sensor) also lidar sensor would be very very good. At the moment I only use canon s100 cameras but looking forward to test other sensors in future when I have budget for it. :-D
  • 100KM
    Did my maiden!
    • Nice. its same size as 60" rc plane.
DIY Robocars via Twitter
RT @SahikaGenc: AWS DeepRacer & Hot Wheels Track https://youtu.be/4H0Ei07RdR4 via @YouTube
Monday
Sep 8
RT @davsca1: We are releasing the code of our Fisher Information Field, the first dedicated map for perception-aware planning that is >10x…
Sep 8
RT @SmallpixelCar: How this works: 1)object detection to find cones in single camera image, 30 frames/sec on @NVIDIAEmbedded Xavier. 2)comp…
Sep 8
RT @SmallpixelCar: Use two color cones to guide the robocar. No map needed, on onsite training needed. Just place the cones and it will fol…
Sep 7
Sep 7
RT @roboton_io: Great to see http://roboton.io running at 60fps on the cheapest #chromebook we could find! #edtech #robotics #educat…
Sep 3
RT @openmvcam: Crazy in-depth article about using the OpenMV Cam for Astrophotography: https://github.com/frank26080115/OpemMV-Astrophotography-Gear https://t.co/BPoK9QDEwS
Sep 3
RT @openmvcam: Hi folks, it's finally here! Our first draft of our Arduino Interface Library is out! It works over SoftwareSerial, Hardware…
Sep 3
RT @chr1sa: Please let them have an open API. This would be perfect for @DIYRobocars races https://twitter.com/NintendoAmerica/status/1301513099707658246
Sep 3
RT @SmallpixelCar: Lanenet pretty much used all my GPU power on @NVIDIAEmbedded Xavier since I optimized with tensorRT. I need to run anoth…
Sep 3
xemone liked Max Gilson's profile
Aug 31
RT @LyftLevel5: Our @kaggle competition on Motion Prediction for Autonomous Vehicles is now live! Experiment with the largest-ever self-dri…
Aug 24
RT @chr1sa: Our next @DIYRobocars virtual AI car race will be on Sept 26th. Sign up here https://www.meetup.com/DIYRobocars/events/272786977/ https://t.co/UENKGSOWO8
Aug 24
New ready-to-run @NVIDIAEmbedded JetRacer car from Waveshare. Perfect for the next @diyrobocars race as soon as we… https://twitter.com/i/web/status/1297960223013867520
Aug 24
DIY Drones via Twitter
RT @chr1sa: The US government just approved 5 US-made drones for purchase, all based on the @Dronecode @PX4Autopilot standard. Great news f…
Aug 20
