ESC Calibration!! Badly need HELP!
Hello guys,
I am trying to get my Arducopter up in the air, but it seems to get more complex than I thought.
I followed all the instructions to build and calibrate it as on the google wiki. However I am facing great trouble getting the ESC calibrated. I setup the radio just fine. Then go onto calibrate the ESC and it gives me the first two beeps. Then when I lower the throttle on my radio it does not give me the final beep. My battery is connected and so is the four wire connector to APM. I have a feeling there is something wrong with the ESC. I have been unable to get my motors spinning. Please advise!
Ammar
  • Confirmed I went back to a older revision(.40) and my ESC's arm properly, using the latest firmware does not arm my ESC's
    Help!
  • Yes you most certainly can hope for one. I think it should be out fairly soon. I know for a fact Neato uses one, but they just dont sell their range finders. If nothing there will be plenty of stereo camera based depth sensors
    Try a manual calibration of your ESCs. Unplug any ESC from the PDB; disconnect power. remove any props.
    Plug the ESC into channel three of the receiver. Raise the throttle to max, and apply power to the ESC in use (only). Wait for it to make noise, twice, then lower the throttle. Repeat for each ESC.
    As for motor spinning, do you know all the commands to arm/autotrim/relevel/disarm your motors?
    If not, then you will want to become acquainted with these tx-based commands.
  • Also I use the 'motors' command in setup and my CLI does not give me any response. I saw from Jani's Youtube video, that it should at least say 'Press Enter to cancel'.... I got this to appear in radio calibration however..
DIY Robocars via Twitter
RT @SmallpixelCar: First time at @wsraceways. After tuning @HokuyoUsa lidar signal and camera sensor on @NVIDIAEmbedded, my car was able to…
yesterday
RT @breadcentric: The handy bit about racing with self-driving cars is that one can type while the car is racing. Report from #AWSDeepRacer…
Friday
RT @chr1sa: Our Bay Area @DIYRobocars meetup is now at 2,700 members. Next in-person events (in Oakland) are training day on July 17 and…
Friday
Videos from the ICRA autonomous racing workshop are now available: https://linklab-uva.github.io/icra-autonomous-racing/
Jun 10
RT @SmallpixelCar: Prepared race track for Warm Spring Raceways @wsraceways and looking forward to test my new car at RAMS RC @ramsaicar fa…
Jun 6
RT @f1tenth: Trying out some nasty blocking maneuvers 🏎️🤖 #f1tenth #autonomousracing https://t.co/nMTstsaogM
Jun 5
May 27
RT @araffin2: I will talk this Saturday from 18:00 to 19:00 Paris time for the @diyrobocars community about learning to race in hours using…
May 27
RT @a1k0n: Luckily the infeasible hairpin problem was easily reproducible in simulation and I could test the fix before bringing the car ba…
May 26
RT @a1k0n: Another problem was that I was over-constraining the car's allowed accelerations, so it didn't think it could turn as tight as i…
May 26
RT @a1k0n: Breaking the map up into two halves worked, but I had to be more careful about separating the inner track from outer. There's se…
May 26
RT @a1k0n: Here's a datalog for my fastest lap of the day. Lap timer is tiny window lower-left. https://t.co/myrlWWrKUY
May 26
May 26
RT @a1k0n: Here was my car's POV. Man this track is confusing in first-person! After the incident my camera was all scuffed up and I was af…
May 23
RT @circuitlaunch: Loved seeing so many familiar (masked) faces at Circuit Launch today for our first in person @diyrobocars in over a year…
May 22
RT @circuitlaunch: Last but not least, mystery guest @BostonDynamics Spot took to the track @diyrobocars He enjoyed the #brazilianbbq too 😂…
May 22
