HiI am 17 and currently building my own quad copter of custom design, however due the complexity of the subject and my problem at hand, i require the assistance of you the professionals if you have the time since I do not wish to keep you from more important mattersI purchased 4 20 amp Esc's ( turningy multi star ), a 1800 mah 3SP1 11.1 v lithium polymer battery, a 2.4 Ghz 6 channel DSM2 spectrum receiver and a kk2.0 controll board I attempted to programme the Esc's so that their rates of revolution was concordant, unfortunately something went not to plan and now I have the following problems :Two motors dial up and remain the same rate consistently, but one has a rate of revolution significantly lesser than the rest while one increases it's revolution rate I suspect to compensate for the slower motor.Also when i attempt to calibrate the Esc's by holding down buttons 1 and 4 on the kk2.0It will display calibration in process but no conformation audio from Esc's has been observedI suspect these problems is down to the fact that I have programmed different Esc's to different settings, in attempt to solve this I purchased an Amatel AVR programmer and a flashing tool, and unfortunately I have yet to find a viable flashing programme that can facilitate the flashing of the DCI chips on each individual incorrectly programmed Esc.Could anyone lease give assistance to this matter
You may find more information from the RC Groups forum HERE.
We do have a few members here that flash ESCs.
You might also consider a simple ESC programming card like the one in THIS VIDEO to determine the state of the ESC.
-=Doug
