I have observed that Mission planner keeps sending heart-beats to the APM. Can someone please clarify if this is a requirement. I am trying to devlelop an application (with limited functionality) that communicates with APM via MAVProxy. The application would wait passively for messages from the APM, which are relayed by MAVProxy and would respond to certain events (Ex: mode changed to RTL, new waypoint reached etc.). The response can include sending commands to APM. I would like to know if there are any issues with this approach (the application not sending heart-beats to APM, but sending commands occasionally). Thank you.
Kasyap
You are correct that the Ground Control Software needs to send a heartbeat packet to the UAV. MAVProxy does this automatically (see send_heartbeat in mavproxy.py) when it is connected to a UAV.
The APM software will go into failsafe if it loses contact with the GCS for more than 5 seconds. There is a setting to disable this failsafe though: http://copter.ardupilot.com/wiki/battery-gps-and-gcs-failsafes/
Hi Stephen,
Thanks for the response. I checked send_heartbeat() in mavproxy.py. So, even if the 'slaves' that communicate with APM via MAVProxy do not send heartbeats, the APM still keeps receiving heartbeats from the GCS (MAVProxy in this case). If there is no heartbeat from the GCS for a period of 5 seconds, 'GCS failsafe' kicks in which can be disabled. This clears my doubt. Thanks again.
Kasyap
Yep, that's exactly it :)
hi ..but I can't open this link
The wiki has undergone significant changes in the last 4 years! Hence the changed link.
Try:
http://ardupilot.org/copter/docs/gcs-failsafe.html
http://ardupilot.org/copter/docs/failsafe-battery.html
