Hello Everyone,
Ok the only crashed I get now are when a prop falls off the quad will in flight. It has cost me two cameras and a good amount of embarrassment. It only happens once every 15 flights but I hate it. So has anyone ever super glued the collet prop ad pater to there motor? It seems even if the motor goes bad at some point a new motor comes with a new collet adapter.
Tags:
I was referring to my post two posts earlier on the page. Basically, I think the adapters that came from 3DR with the motors are poorly designed/machined and are not suitable for use. And if you're going to go through the trouble of changing the shafts on your motors, you might as well get new prop adapters and use whatever is the best shaft for those.
I'm going to give the bolt-on adapters a shot, and (eventually) find out what kind of damage is done when I (inevitably) whack another prop on the ground.
I've used these in the 3DR motors with no problems.
http://www.goodluckbuy.com/replacement-3-17mm-shaft-for-brushless-o...
45 members
1472 members
282 members
470 members
57 members
Powered by
