[HELP]ArduPlane no more Throttle after switch to any assisted mode
hi folks,
finishing my plane, and did some testing.
I am facing one issue regarding throttle.
In manual mode everything is fine, when i switch to stabilize mode, no more throttle, same for rtl.
am i missing something? first time it does that to me.
thxx for your help and your time.
best regards
re- In manual mode everything is fine, when i switch to stabilize mode, no more throttle, same for rtl.
Are you talking about in flight or on the bench? That is normal on the bench as if apm detects it's not moving aka on the ground as a safety feature it will not throttle up. I had this problem trying to set my cruise throttle percentage with a nitro engine. I ended up driving around the block with it in stabilize mode just so I could see were 45% cruise throttle was.
yep that s what i was sayin, i ll try maybe tomorrow see how it goes.
thxx a lot for your time!
