Help for Newbie with arm dipping and crash
Hello,
I'm brand new to RC and drone and just built my 1st drone, a 3D Robotic QuadCopter.  VERY COOL!  Unfortunately it crashed.  I noticed that one of the motors would stop suddenly and the arm would dip, then recover.  Did this about ten times over the three flights.  Finally did it while in loiter mode while close to the ground, crashed and broke the prop :(.
It was hard for me to tell orientation, so I could not tell what motor was stopping.  I'm hoping one of you experts out there can look at the log file and share your expertise.  To me it looks like both roll and pitch went high which I think means the right rear motor dipped (running in X mode).
So, my two questions are:
  1. Which motor is stalling?
  2. What can be causing this?
  3. What troubleshooting steps can I take to confirm failure mode.
Thanks,
John
2012-12-31%2018-17%20-1.log
  • From your log I cannot tell which motor had an issue. You will need to turn on the 'motors' option throught the CLI, command line interface.
    Look over THIS somewhat lengthy dicussion for the details and more insight into your machine.
    HERE is the motor/orientation information you mentioned.
    At least you have the correct code loaded for your quad and orientation...
    3692579606?profile=original
    That is half the battle when it comes to maiden flights.
    -=Doug
DIY Robocars via Twitter
Practice virtual race this Saturday; the real thing will be on Oct 3 https://www.meetup.com/DIYRobocars/
yesterday
yesterday
Derrick Davies liked lisa TDrones's profile
yesterday
Monday
RT @SahikaGenc: AWS DeepRacer & Hot Wheels Track https://youtu.be/4H0Ei07RdR4 via @YouTube
Sep 14
Sep 8
RT @davsca1: We are releasing the code of our Fisher Information Field, the first dedicated map for perception-aware planning that is >10x…
Sep 8
RT @SmallpixelCar: How this works: 1)object detection to find cones in single camera image, 30 frames/sec on @NVIDIAEmbedded Xavier. 2)comp…
Sep 8
RT @SmallpixelCar: Use two color cones to guide the robocar. No map needed, on onsite training needed. Just place the cones and it will fol…
Sep 7
Sep 7
RT @roboton_io: Great to see http://roboton.io running at 60fps on the cheapest #chromebook we could find! #edtech #robotics #educat…
Sep 3
RT @openmvcam: Crazy in-depth article about using the OpenMV Cam for Astrophotography: https://github.com/frank26080115/OpemMV-Astrophotography-Gear https://t.co/BPoK9QDEwS
Sep 3
RT @openmvcam: Hi folks, it's finally here! Our first draft of our Arduino Interface Library is out! It works over SoftwareSerial, Hardware…
Sep 3
RT @chr1sa: Please let them have an open API. This would be perfect for @DIYRobocars races https://twitter.com/NintendoAmerica/status/1301513099707658246
Sep 3
RT @SmallpixelCar: Lanenet pretty much used all my GPU power on @NVIDIAEmbedded Xavier since I optimized with tensorRT. I need to run anoth…
Sep 3
RT @LyftLevel5: Our @kaggle competition on Motion Prediction for Autonomous Vehicles is now live! Experiment with the largest-ever self-dri…
Aug 24
