Help me understand servos?
Apologies for being dense on this, my brain just isn't grasping this.
We have a hexcopter with an APM 2.6, power supply, lipo battery.  Its currently wired battery > power supply > apm > out.  I have also ran the 5v out from the power supply to the apm.  JP1 is pulled. Motors work, electronics work, everything works great.
Now its time for the servos.  We're using a Tarot X6 frame which has retractable landing gear.  This uses a servo input from the APM to control it.  Which output on the APM should I use?  We will also be using a gimball which will need 2 outputs.  We are using an 8 channel Futaba receiver if that is useful info.  I've read probably 20 pages on ways to hook this up and my brain just isn't processing it.
Next question which will probably help me understand my first question:  Why do I need to run power from the BEC to the APM if I have servos?  Its already getting +5V from the power supply, why do I need +5V from the BEC?  I understand the 6S battery is putting out 22V and that needs to be knocked down to 5V for some things, I get that.  But why do I need 2 different +5V inputs?
Thanks for any help.
  • Josh,
    I wrote a little blog entry when I wrestled with this problem on my Tarot 650s. Might help
    http://www.rcgroups.com/forums/showthread.php?t=2333925
  • Sorry.
    Which output to control the landing gear servo?
  • Because the power supply that feeds the APM will not supply sufficient current to both the APM and the servos at the same time. Once the demand from the servos comes on, voltage can drop enough to "brown out" the APM, thereby killing your copter if it happens to be flying. Putting a separate BEC on the output rail while JP1 is pulled allows for a separate power to the servos, without the likelyhood of it affecting the autopilot itself.
    • That makes a ton of sense.  Thanks!
      So which output on the APM would be best?
      • For powering the output rail? IIRC any output that you're otherwise not using. Check with the wiki.
DIY Drones via Twitter
RT @chr1sa: My talk on PX4 and FAA certification is coming up at 1:45 PST today on the PX4 Dev Summit livestream. Includes some cool new st…
Tuesday
RT @seesharp: I'm tuned into the PX4 / Dronecode free live conference. Great stuff. Microsoft AirSim talk in 10 minutes. https://t.co/0zbZ2…
Monday
DIY Robocars via Twitter
RT @masato_ka: 距離センサを3つとESP32を付けたラジコンカーをDonkeyCarライクにNNで自動走行。3層FC極小モデルをTensorFlow Lite for microcontrollerで動かしてる。機体は借り物でRumiCarって言います。Tenso…
Monday
RT @SmallpixelCar: My car was able to go all the way autonomously until the crosswalk. It was only 100 yards from the target. What should b…
Jul 4
Liam left a comment on Agricultural UAVs
"Hi
I'm Liam from T-MOTOR. I would like to reach out to see if there is any possibility for us to work together.
We are a propulsion system manufacturer who offers motors, propellers and ESCs for all kinds of drone applications which vary from secur…"
RT @SmallpixelCar: Smart move. The car used the shadow to guide it through the bridge. This was never in the training samples. But it learn…
RT @SmallpixelCar: Getting closer to the target. Single camera. Untrained road. https://t.co/Wsr7RwDamj
Jun 29
Richard Cox left a comment on Australia
"Anyone in the DIYDRONES Australian subgroup based in Alice Springs, NT?
I am experimenting with Ardupilot (standard Arduplane), Pixhawk 4 FC in a 4-ch
RC "AXN Floater Jet" foamy plane..."
Jun 29
Omar Sykes left a comment on Australia
"Hi everyone, I am looking for someone who is good at drone building, repair and software in Adelaide. Please give me a call on 0477 319 219."
Jun 29
RT @RoboticMasters: #donkeycar https://t.co/czuLoVRcA4
Jun 29
https://t.co/DKQbNTbz0g
Jun 29
RT @RoboticMasters: Donkey car, car car car car car car; Donkey car, car car car car car car; Donkey Car. Anyone like our tiny tiny donkey…
Jun 29
RT @SmallpixelCar: After improving DBSCAN speed, I can get 11 frame per second on @NVIDIAEmbedded Jerson Xavier MAXN mode and the autonomou…
Jun 26
RT @Heavy02011: Join us at next Virtual Race League: ⁦@diyrobocars⁩ Race #4 - Parking Lot Nerds, August 1st https://t.co/5KUpu7VGaH
Jun 25
RT @SmallpixelCar: #CUDA implementation should be easy, because most of the time is on distance calculations berween two points and if the…
Jun 25
RT @SmallpixelCar: This is the view from the car. Even my lanenet inference is fast on @NVIDIAEmbedded Jerson Xavier, DBSCAN clustering tak…
Jun 25
