Help, My Oilpan is Broken! SMT Solder Tips Needed.
Ok, needs some hardware folks to tell me how to fix my Oilpan.  Either I've been using the USB plug too much or, due to my recent rough flying, the USB plug on my Oilpan has come off.
I'm totally inept at surface mount soldering, so the questions I have are, and would appreciate any tips.
Questions I have are:
1- Should just sit the plug back on the traces, and solder the four corners only, without soldering 5 little pins?
2- How the heck am I going to solder the pins, if I have to?  There's plastic on the connector.
3690911781?profile=original
  • I tore mine off, and did manage to solder it back on. I ground a solder tip to a needle point.  I put the plug in position, the little studs really help.  Then I soldered the corner tabs on first. I added just a bit of solder to these.  Then, I simply touched each of the 5 circuit pins, and they reflowed.
    It actually wasn't that bad.  And yes, it works.
