I am new to UAV/Drones. Me and my friends have been looking to find some drones that are kinda cheep maybe some used ones or something like that.How much would it be to make a drone/UAV With thees capabilities?I would like to buy a ready to fly UAV. I would like to be able to program flight plain using pc and have it stream data and video back to the pc while still in flight. Have a good battery life and be able to go pretty far from the "command center" How much would that cost or how would I go about making one myself? Help me out some one thanks.Thanks for your timeKristopher
  • Maybe you guys would be interested in this: (from my company)
    https://www.event38.com/ProductDetails.asp?ProductCode=E382
    It's made primarily for aerial photography but it's a big, stable frame, easily modified with widely available replacement parts. No video yet, and still needs an R/C transmitter. Check it out and let me know if you have any questions. Thanks!
    You might find better help if you explained some requirements you have in useful ways.
    - What quality of video data? Does it need to be streamed live, or can it be recorded, then played back after? NTSC, PAL, HD? 5fps? 15fps? 120fps@1024p?
    - What does "good battery life" mean? How long is "good"?
    - What does "go pretty far" mean? How far is "pretty far?" Please answer in feet, meters, kilometers, or miles.
    - Are there any other requirements you have? The list above is too narrow. For example:
           - Do you need it to fly fast? If so, how fast?
           - Do you need it to fly in wind? Remember, if there is 10kph wind, then it needs to fly at least 10kph just to stay still
           - Does it need to hover?
           - What kind of PC do you have, or can you get? Linux? Windows XP? Windows 7? Windows 8? Mac?
           - Do you know what kind of radios you need? See my questions about range above. It is also helpful, to pick radios that will work, to know more:
                         - In what country do you plan to fly? This is important because there are different rules for what types of radios are ok, and which frequencies you can use. Which freqencies are important because they function over different distances, and also because your video and your other radios (telemetry) have to play nice with your GPS, etc.
                         - Do you plan to fly day or night or both? This is important for many reasons, the kinds of cameras you use, and also because radios work differently in the day and night, slightly, and because you might want lights on your UAV.
                         - Do you plan on flying in places with lots of trees? If so, evergreens or decidious? THis is important for radio selection (video and telemetry)
                         - Will you be able to see the UAV? This is also important for the selection of your radio. Some radio frequencies need to be able to "see" directly, called line of sight, and if there is anything in the way, then the signal gets blocked. See my question about trees, but it is also important to know if you plan to fly around buildings, or near large bodies or water, or near large metal structures. These can all cause problems with radio, so if you do need to do any of this, it is best to list what you need, so the right frequencies can be picked. If you cannot see the UAV, the radios may need to be very different, but it is not as easy to just swap them out, because you also need to have the correct antenna for it, and that most likely means different weight. Weight is very, very important, so it is better to have as many details before you spend money .... especially if you want to keep the cost down.
    Answer some of these questions, and you might have more success.
  • wow that is expensive any way to get it cheaper ?
  • Here you go: http://www.lehmannaviation.com/la/la100.php
    Costs around $1300
    Lehmann Aviation | Utility Drones since 2005
    For more than 10 years Lehmann Aviation develops and manufactures ultra-rugged and cost-effective utility drones for the most demanding missions arou…
  • Would any one like to make a UAV for me ? If you would like to at least help me come up with a designe for it I would like that very much you can contact me through email
    akjroller@gmail.com
  • Well does any one think that thay would like to take on this type of project? If so contact me by email at akroller@gmail.com we can pan out the details.
  • I do not want any RC control I want to be able to set a fight path for it and make it go and maybe not transmitting any video would that cut down on the cost?
    See http://www.diydrones.com/profiles/blogs/a-newbies-guide-to-uavs
    It will cost $420 (ARF) to $700+ depending on what options and r/c control you opt for
    See http://store.diydrones.com/category_s/28.htm for quads, but the flight times are in 10s of minutes best. Or you could try a plane for longer flights.
    If you want video, you will need a video transmitter as well, which can be an extra $200+ dollars depending on what setup you want, and there's many options. Search for FPV (first person view)
DIY Robocars via Twitter
Practice virtual race this Saturday; the real thing will be on Oct 3 https://www.meetup.com/DIYRobocars/
5 hours ago
5 hours ago
Derrick Davies liked lisa TDrones's profile
7 hours ago
Monday
RT @SahikaGenc: AWS DeepRacer & Hot Wheels Track https://youtu.be/4H0Ei07RdR4 via @YouTube
Sep 14
Sep 8
RT @davsca1: We are releasing the code of our Fisher Information Field, the first dedicated map for perception-aware planning that is >10x…
Sep 8
RT @SmallpixelCar: How this works: 1)object detection to find cones in single camera image, 30 frames/sec on @NVIDIAEmbedded Xavier. 2)comp…
Sep 8
RT @SmallpixelCar: Use two color cones to guide the robocar. No map needed, on onsite training needed. Just place the cones and it will fol…
Sep 7
Sep 7
RT @roboton_io: Great to see http://roboton.io running at 60fps on the cheapest #chromebook we could find! #edtech #robotics #educat…
Sep 3
RT @openmvcam: Crazy in-depth article about using the OpenMV Cam for Astrophotography: https://github.com/frank26080115/OpemMV-Astrophotography-Gear https://t.co/BPoK9QDEwS
Sep 3
RT @openmvcam: Hi folks, it's finally here! Our first draft of our Arduino Interface Library is out! It works over SoftwareSerial, Hardware…
Sep 3
RT @chr1sa: Please let them have an open API. This would be perfect for @DIYRobocars races https://twitter.com/NintendoAmerica/status/1301513099707658246
Sep 3
RT @SmallpixelCar: Lanenet pretty much used all my GPU power on @NVIDIAEmbedded Xavier since I optimized with tensorRT. I need to run anoth…
Sep 3
RT @LyftLevel5: Our @kaggle competition on Motion Prediction for Autonomous Vehicles is now live! Experiment with the largest-ever self-dri…
Aug 24
