Host Path Setting
I am following below link for setting up SITL on windows....
http://dev.ardupilot.com/wiki/setting-up-sitl-on-windows/
Below are the issues i am facing,please help me...
  1. I am bit confused about statement - If possible give me some example path
    • “Host Path” to folder one level above where you have installed ardupilot software
  2. 4. Open Terminal window and type “ls /mnt/hgfs” and the share you set-up should be visible
    5. type “ln -s /mnt/hgfs/<foldername>” (where <foldername> is replaced with the name of the folder you set-up) to create a symbolic link to the shared folder from your home directory - Here I struck up
  3. Set 4 also not able to do
Can anyone please explain me with brief expalnation?
Thanks in advance.
