MR60
I would lile to use the Survey function in mission planner which uses the CAM_TRIG_DIST method to trigger a camera at regular distance intervals.
I'm using an infrared camera trigger which is activated by a PWM signal (configurable).
The question is on the Pixhawk board, how do I configure the PWM output pin that is triggered by CAM_TRIG_DIST ? Is there a parameter somewhere or is it hardcoded to s specific pixhawk output port ?
Thx for quick help, I have to do some photogrammetey shoot tomorrow !
  • MR60
    Thanks Aforsyth, this is the answer I needed.
    As I use a NEX5 camera triggered by an IR device which is itself triggered by a PWM servo signal, I can thus use Cam_trigg_dist with pixhawk AUx1 (and mapping ch7 to this AUx1).
    I'm impatient to try it out!
    • @hughes, I've read / followed your IR trigger setup instructions and myself have a Nex5 and Strattosnapper2 trigger. For some reason, the flight data servo commands "toggle" and "high" will trigger the camera just fine, but the "Trigger Camera NOW" right-click command and the DO_SET_CAM_TRIGG_DIST do not activate trigger. Any idea what I might be doing wrong?
  • T3
    @aforsyth Thanks for the link! Good to know!
    The wiki does not mention that it is not working with Pixhawk.
    But: "Stay tuned for a 3DR CHDK cable" . Any update on this?
    • I have not heard any more news from 3DR on any attempt on their side to address the incompatibility of the Pixhawk and CHDK cameras, but I have heard they are working on a board specifically designed around camera control.
      As mentioned in the github post, we are working on integrating this voltage stepper into our system for the time being:
      https://www.sparkfun.com/products/10968
      • T3
        The problem is it all means more weight. This is why I like the simple solution for the APM. Camera control board sounds good. Some teaser 3DR?
  • Howdy,
    You might find some useful information at this post:
    https://github.com/diydrones/ardupilot/issues/785
DIY Robocars via Twitter
RT @SahikaGenc: AWS DeepRacer & Hot Wheels Track https://youtu.be/4H0Ei07RdR4 via @YouTube
Monday
Sep 8
RT @davsca1: We are releasing the code of our Fisher Information Field, the first dedicated map for perception-aware planning that is >10x…
Sep 8
RT @SmallpixelCar: How this works: 1)object detection to find cones in single camera image, 30 frames/sec on @NVIDIAEmbedded Xavier. 2)comp…
Sep 8
RT @SmallpixelCar: Use two color cones to guide the robocar. No map needed, on onsite training needed. Just place the cones and it will fol…
Sep 7
Sep 7
RT @roboton_io: Great to see http://roboton.io running at 60fps on the cheapest #chromebook we could find! #edtech #robotics #educat…
Sep 3
RT @openmvcam: Crazy in-depth article about using the OpenMV Cam for Astrophotography: https://github.com/frank26080115/OpemMV-Astrophotography-Gear https://t.co/BPoK9QDEwS
Sep 3
RT @openmvcam: Hi folks, it's finally here! Our first draft of our Arduino Interface Library is out! It works over SoftwareSerial, Hardware…
Sep 3
RT @chr1sa: Please let them have an open API. This would be perfect for @DIYRobocars races https://twitter.com/NintendoAmerica/status/1301513099707658246
Sep 3
RT @SmallpixelCar: Lanenet pretty much used all my GPU power on @NVIDIAEmbedded Xavier since I optimized with tensorRT. I need to run anoth…
Sep 3
xemone liked Max Gilson's profile
Aug 31
RT @LyftLevel5: Our @kaggle competition on Motion Prediction for Autonomous Vehicles is now live! Experiment with the largest-ever self-dri…
Aug 24
RT @chr1sa: Our next @DIYRobocars virtual AI car race will be on Sept 26th. Sign up here https://www.meetup.com/DIYRobocars/events/272786977/ https://t.co/UENKGSOWO8
Aug 24
New ready-to-run @NVIDIAEmbedded JetRacer car from Waveshare. Perfect for the next @diyrobocars race as soon as we… https://twitter.com/i/web/status/1297960223013867520
Aug 24
DIY Drones via Twitter
RT @chr1sa: The US government just approved 5 US-made drones for purchase, all based on the @Dronecode @PX4Autopilot standard. Great news f…
Aug 20
