hi I'm new with arducopter, it been a week since i begin to figure out how to show motors log, i had already saw this tutorial,  but the motor still not show  this what i already do:
i use APM 2.6
1. set StandarParameter>LOG_BITMASK to Default + Motors
2. turn on and do the take off with  my Arducopter(Quadcopter), motor run as expected
3. download the log but when i check the DataFlash log i can't find the motor data
Here my log Visual with Mission Planner after i set the LOG_BITMASK to Default+Motors
but in the .tlog file i got servos data, is that same as motor data ?
thanks in advance
- In Standard Parameter, LOG_BITMASK, select RCout
- after flight download Data flash log (with USB cable )
- then select "Review a Log" and look for file ending with .bin
-on graph screen select RCOU and select Chan1, Chan2, Chan3, Chan 4 (for the amount of motors you have)
