It took 4 days of painful work, but i finally got there. I consider this the base for my UAV experience. The transmission is incredibly stable, the video is really smooth. Here is what i used:
-Logitech C920, a good quality camera.
-Pandaboard: has an embedded video encoder that can take the raw YUYV video from the camera and encode it in h264. You can set the encoding quality/bitrate and other parameters.
-HSDPA usb dongle; 60 hours of high speed connection for 10€/month, i have a 2Mbps upload speed with this little beast. Ping increases during workload and reaches 250ms, when unused, it's as low as 50ms.
-The traffic is sent from the pandaboard to a VPN i connect with my client. This is only a way to bypass firewalls.
864x480 works but it's not as smooth as 360p, and i consider the 360p streaming to be more than enough for this. 1280x720 lags considerably.
If there is interest maybe i can publish my code and a video of how it works. Anyway, i'm a happy guy and i wanted to share it. I've never tried radiofrequency video transmission, but was worried about the range.
Now, i don't have to worry about it anymore ;)
  • I am trying to do the same with raspberry, but it dosnt see dongle as 3g modem,, it see as storage. Can you help?
    thanks
  • Nice setup, but why not encoding to H264 using the camera processor ?
  • We have just launched a digital FPV solution utilizing a cellular network using similar hardware on Indiegogo:
    http://skydrone.aero/fpv-indiegogo
    You might also want to check out our blog entry on diydrones.
  • Here are the scripts i use.
    Nothing special, but they works.
    Yes, i'm using the pandaboard ducati hardware encoder.
    script.tar.gz
  • Good job.!!!! Like others I'd like to see how it work in sources. Did you used gstreamer with plugins for TI Omap DSP?
  • Great stuff! I hear that mobile phone towers are quite directional and pointed down. Would be good to see how this goes in the air! Unlimited FPV range!
  • This is some great work! I'd love to be able to see the code for that, although I'm far away from being able to use it at the moment.
DIY Robocars via Twitter
Practice virtual race this Saturday; the real thing will be on Oct 3 https://www.meetup.com/DIYRobocars/
Wednesday
Wednesday
Derrick Davies liked lisa TDrones's profile
Wednesday
Monday
RT @SahikaGenc: AWS DeepRacer & Hot Wheels Track https://youtu.be/4H0Ei07RdR4 via @YouTube
Sep 14
Sep 8
RT @davsca1: We are releasing the code of our Fisher Information Field, the first dedicated map for perception-aware planning that is >10x…
Sep 8
RT @SmallpixelCar: How this works: 1)object detection to find cones in single camera image, 30 frames/sec on @NVIDIAEmbedded Xavier. 2)comp…
Sep 8
RT @SmallpixelCar: Use two color cones to guide the robocar. No map needed, on onsite training needed. Just place the cones and it will fol…
Sep 7
Sep 7
RT @roboton_io: Great to see http://roboton.io running at 60fps on the cheapest #chromebook we could find! #edtech #robotics #educat…
Sep 3
RT @openmvcam: Crazy in-depth article about using the OpenMV Cam for Astrophotography: https://github.com/frank26080115/OpemMV-Astrophotography-Gear https://t.co/BPoK9QDEwS
Sep 3
RT @openmvcam: Hi folks, it's finally here! Our first draft of our Arduino Interface Library is out! It works over SoftwareSerial, Hardware…
Sep 3
RT @chr1sa: Please let them have an open API. This would be perfect for @DIYRobocars races https://twitter.com/NintendoAmerica/status/1301513099707658246
Sep 3
RT @SmallpixelCar: Lanenet pretty much used all my GPU power on @NVIDIAEmbedded Xavier since I optimized with tensorRT. I need to run anoth…
Sep 3
RT @LyftLevel5: Our @kaggle competition on Motion Prediction for Autonomous Vehicles is now live! Experiment with the largest-ever self-dri…
Aug 24
