Strange end of auto mission today.
I wanted to trig the battery failsafe at 10.5V and check reaction while Iris+ was loaded with a 250 grams camera. So I gave him a mission with 18 very close parallel lines, 200m long.
When turning for the last line, sudden lost of altitude while telemetry was still given 10.8. And finaly badly land and flip over. One of the last turns I saw also a lost of altitude, but Iris recovered.
Battery log shows no error, but I observe a lot of max values for ThrOut. Max throttle did not keep Iris in the air.
Not even a crash event was logged
Only change I made from previous satisfactory config is update to 3.2.1 and EKF enabled.
Any idea of what happened ?
I put log in next post
the log file
Based on the log of the motors it was too heavy to keep it in the air.  Motor 3 was pinned both times it lost altitude.
Thanks for your answer Michael
300 gram with support being too heavy for Iris+ ?
The point is that I used to fly like this before without problem. Having a problem on motor 3 only can be a calibration issue ?
BTW, the motor 3 activity indication is RCOU / Chan3 ?
Right, upper left motor.  They all clamped at 1950.
The IRIS is rated at 400 grams so don't know why it had a hard time.
parameter comparison between previous values (in the "new value" column) when Iris was flying correctly. Any of these discrepencies can cause the misbehaviour ?
