I have upgraded to a 1 watt radio, but even with good dipole antennas I am only getting around 800 meters through trees and buildings (much more when up in the air of course). Better antennas may help, but I am considering using more power and 5 watt amplifiers appear to be possible to connect to the 3DR/Hope transmitter modules. I am concerned about transmitting and receiving with one module though. Has anyone done this before and know if the receiver circuit could be disconnected from the transmitter and bypass the 5 watt amplifier, so that it could transmit and receive half duplex with one antenna?
  • I cant help but think that this would ACE my current project :P diydrones.com/forum/topics/hoperf...
    • Yes, that would be nice. You might have to overpower the other person's transmitter. A 5 watt linear amplifier would probably work for transmitting and you could use a second module for receiving (and two antennas), but it might be worth experimenting to see if you could connect the receiver to the transmitter and have one small module.
  • More power is generally not the best solution. It will add to your problems in most cases.
    Usually antenna placement and checking RF cables for loss will help. In most systems poor quality cable and connectors will have the greatest effect.
    You can connect a 5W linear amplifier and it will work. I assuming the 5W Liner amp has a built in 'RF switch' so the transmit power doesn't reflect directly onto the receiving stage. Unless you are building a home-brew solution?
    That said using more power may give you distance when line of sight, but trees and buildings are exceptionally good attenuators at these frequencies
    FWIW, we're getting 30km comfortably with RFD 900's, with a 900MHz patch antenna on the vehicle and two OEM stick-on dipoles on the plane. I think their max power is 1W.
    5W seems overkill unless you want to go 60km+?
    21km on a bad day with RSSI's in the 90's:
    3702148448?profile=original
    • 30km is very good. I don't feel that I need 30km or 60km of range, but I am more concerned about poor reception when flying low near trees or around hills.
  • yes, it's possible to transmit at 100W too, that would be equally illegal in most countries, and equally bad for all those other devices you would interfere with.
    • True in most cases, but I have an amateur radio license and I plan on doing it legally like APRS data packets on 440mhz. Amateur handheld transceivers use 440mhz at 5 watts legally and don't interfere with anyone.
      • then you would know difference between mhz and Mhz ?Β
        -sorry , but you asked for it :)
        • and between Mhz and MHz...
DIY Robocars via Twitter
yesterday
RT @_JonMyer: 🏎 We need your help in naming my #AWS DeepRacer Underground Track 🏎 @davidfsmith's track is going to be referred to as 𝗔π—ͺ𝗦 𝗗…
Thursday
RT @gclue_akira: δ»•δΊ‹γ‚‚γŠγ‚γ£γŸγ—γ€ι›»θ„³εŒ–γ«γ¨γ‚‰γ„γ€€#γƒžγƒͺγ‚ͺγ‚«γƒΌγƒˆγƒγƒƒγ‚― https://t.co/4IU90hCLgm
Thursday
This is the hashtag to follow all the people in Japan who are hacking the new Nintendo Mario Kart with the real AR… https://twitter.com/i/web/status/1319281354664677376
Thursday
RT @gclue_akira: @chr1sa @diyrobocars jupyter mario https://t.co/P0oHdjlCRq
Thursday
RT @_JonMyer: 🚨Our 1st AWS DeepRacer Community Race is Underway on http://twitch.tv/aws 🚨 Join us to find out which member of your commu…
Tuesday
Monday
RT @BackyardRobotcs: After an admittedly long wait, the new Tinymovr R3.3 motor controller is now available https://tinymovr.com πŸ₯³
Monday
RT @_JonMyer: 🏎 1 hr left before the #AWS #DeepRacer Community 🏎 Top 5 Race tomorrow LIVE on Twitch 1st Place = $50 Amazon GC or AWS Credit…
Monday
Oct 16
Oct 15
Oct 14
RT @davidfsmith: Race virtually with The AWS DeepRacer Community Race and then join us on the track to see how your times compare on the ph…
Oct 14
Oct 14
Hiroki Tanaka liked Hiroki Tanaka's profile
Oct 13
RT @breadcentric: It's now!
Oct 13
