Is it safe to use ch8 input on Arducopter now?
I recall reading on the WIKI that ch8 input should never be used with arducopter code, in that it triggers manual output of the PWM signals. Is this still true with the later code? I'm already using channel 6 and 7 for gimbal control and was hoping to use ch8 input for switching screens in minimosd.
  • Terrific. Thanks for the clarification. So I should then flash the ArduPPM_v0.9.87_Arducopter-APMv1.4.hex to the PPM encoder that doesn't have the CH8 passthrough support. Is that right?
  • 100KM
    The ch8 hardware failsafe is handled by the PPMencoder, not by the main arducopter or arduplane software. So if you have an APM1.4 with oilpan and you haven't reflashed the ppm encoder, then yes, CH8 will still trigger manual output of the pwm signals on the first 4 channels. To get rid of it you need to reflash the ppm encoder chip.
xemone liked Max Gilson's profile
Aug 31
nick rymer left a comment on ArduCopter User Group
"I recently switched laptops and now have Windows 10. I installed Mission Planner on my laptop and plugged a mRo SiK Telemetry Radio into the USB port. The radio is not recognized on the com ports but is instead on the "Other Devices" tab in Device…"
Aug 20
