  • No problem, what I've got for my octo setup
    Droidworx AD8 HL 360 Airframe ( I am in the process of designing and making my own carbon fiber frames at much more affordable costs if you are keen)
    AV200 pro 360 camera mount
    Ardupilot Mega+IMU kit x 2 (one for camera mount stabilization)
    8 x 350w brushless motors (these are the Mikrokopter ones, MK3638) but any would work fine
    8 x 25A(30Amax) ESC for motors
    Custom made pdb using cables soldered to give each motor power
    a few 5000mah 4S lipos
    JR DSX9 radio + receiver
    (i dont use GPS on the octo as it not needed at all for us)
    signal cables from esc goes to 1,2,3,4,7,8, and then the pins, PB5 (10) and PE2 (11)
    code you need to replace is very easy using Arduiono software in the APM_Config.h file replace
    #define FRAME_CONFIG QUAD_FRAME  with #define FRAME_CONFIG OCTA_FRAME
    that's it!
    Build, setup your board, calibrate radio (with no props!) and your set. No need to mess with any settings, they all work 100%
    Hope this helps,
  • Iv build a octo with ardupilot(arducopter) and droidworx frame works perfectly and sooo stable. msg me if u need any help once u know how its very simple and straight forward, just follow the exact same steps as for the quad but solder 7+8 to the other pins as mentioned above. you need to upload octo setup to board via arduino 22 software and replace a very simple string of code. i will make a full how to when i get a gap. hope this helps.
    There are two pins used for the last two motors of the octa. These last two pins are not the 8 regular servo out pins. They are PB5 for channel 10 and PE3 for channel 11
    The Wiki Diagrams should help you locate the motor positions and the Pin names are screen printed on the base of the APM board.
    Good luck.
    jason
DIY Robocars via Twitter
RT @TinkerGen_: "The Tinkergen MARK ($199) is my new favorite starter robocar. It’s got everything — computer vision, deep learning, sensor…
Monday
Monday
RT @roboton_io: Join our FREE Sumo Competition 🤖🏆 👉 https://roboton.io/ranking/vsc2020 #sumo #robot #edtech #competition #games4ed https://t.co/WOx…
Nov 16
DIY Drones via Twitter
First impressions of Tinkergen MARK robocar https://ift.tt/36IeZHc
Nov 16
Our review of the @TinkerGen_ MARK robocar, which is the best on the market right now https://diyrobocars.com/2020/11/15/first-impressions-of-tinkergen-mark-robocar/ https://t.co/ENIlU5SfZ2
Nov 15
RT @Ingmar_Stapel: I have now explained the OpenBot project in great detail on my blog with 12 articles step by step. I hope you enjoy read…
Nov 15
RT @DAVGtech: This is a must attend. Click the link, follow link to read the story, sign up. #chaos2020 #digitalconnection #digitalworld ht…
Nov 15
RT @a1k0n: Got a new chassis for outdoor races (hobbyking Quantum Vandal) but I totally didn't expect that it might cause problems for my g…
Nov 11
First impressions of the Intel OpenBot https://ift.tt/36qkVV4
Nov 10
Nov 9
Excellent use of cardboard instead of 3D printing! https://twitter.com/Ingmar_Stapel/status/1324960595318333441
Nov 7
RT @chr1sa: We've got a record 50 teams competing in this month's @DIYRobocars @donkey_car virtual AI car race. Starting today at 10:00am…
Nov 7
Nov 6
RT @a1k0n: Car's view, using a fisheye camera. The ceiling light tracking algorithm gave me some ideas to improve ConeSLAM, and having grou…
Nov 5
RT @a1k0n: To get ground truth I measured the rug, found the pixel coordinates of its corners, calibrated my phone camera with my standard…
Nov 5
RT @a1k0n: @DIYRobocars is back in December, but outside. Time to reinvestigate ConeSLAM! I rigged up a quick and dirty ground-truth captur…
Nov 5
