JOYSTICK CONTROL I think Ive found something interesting!
G-day,
I have been a fan of  drones ( be it fixed wing, quad, or tricopter ) for a long time.
I love the concept of FPV, and am currently trying to build my first.
I found a really awsome little bit of hardware that transforms your RC TX from hands on - to sitting on a table ....while you fly with your JOYSTICK!
The units is called an " FPV SYSTEM  1.5 " in basic terms, you simply plug a cable ( included ) in with the kit, into the  Master control port on your RC's TX. - from there simply set your channels up for either mode 1 or mode 2 ( you DO need to make your adjustments only once ) then - just flip the switch to MASTER on your TX an your up!
The TX controls are disabled, and your joystick now runs your aircraft.
check out the link below - I'm seriously considering getting one but I will of course do more research on it.
The units cost is $75 if you go an search their website, you will find it -along with lots of other ods and ends for FPV an RC,
Hope this helps
cheers all.! - check out the link below....
http://www.aeorc.com/english/?product-324.html
Rick,
Sounds a lot like a copy of the existing PCTx PC to TX interface.
TCIII
