We VTOLized the Raptor E1, at the same time we further optimized the power plant to achieve 50-80 Watt power consumption at cruise speed at 16.5 m/s with 3.5 Kg payload.
 All in all very happy with the conversion. If anyone interested we are taking pre-orders to setup a manufacturing line with an aerospace composite partner company in England UK. This would allow us to release a high quality full composite platform at an accessible price tag.
Check http://www.raptoruas.com/ev.html for more info
Why not put the motor wires inside the tube arms? Looks really tacky and unprofessional with them hanging loose with just the odd cable tie.
5 hours duration on LiPo's is a pretty ambitious claim, do you have a log or video to back that up?
Yes, agreed, this is the first conversion of the VTOL proto, so yes a bit rough
Can't say I agree there is anything ambitious about this, it consumes 50-80 Watt at level cruise at 16.5 m/s at 3.5 Kg payload.with 200 Watt during turns But you are right we should back this up.
 Would people be happy with a G-code verified GPS tracklog, what is it that people would like to see? and we will produce it.
We have spent significant time in optimizing the power plant and the endurance is a product of the platforms aerodynamics and the power plant optimization.  I will say only one thing, the reason other UAVs are not achieving long endurance at least based on what we see is 1) wrong airfoil thickness, 2) high wing loading.
Does it not contain your partner's fuel cell??
https://www.suasnews.com/2015/09/uk-singapore-collaboration-prepare...
I'm interested in what you say about aerodynamics as are not all of those negated with four extra props and associated gubbin s being dragged along for the ride most of the flight?
As regards proof, this is how we did it in the case of one manufacturer, I sent somebody to stand on an airfield to watch a six hour flight.
We can do that again!
2+ hours with LiPo's takes a bit of doing, with Li-Ion it's a bit easier but 5 hours is a real challenge especially if it's going to do a VTOL takeoff and landing.
So I'd suggest doing a documented duration test, and post the log from whatever flight controller you're using. Or plot the flight out on Google Earth. Also use the test as a distance check. Calculations and real world tests can vary considerably. Only a very few have exceeded 200km and that's with highly optimized planes (non-VTOL) and very little payload.
No it doesn't, just a 28,000 mah LiPo
Without the VTOL conversion the standard system is capable of more than 6 hours with the same battery.
But as I said the two most important points other fixed wing UAVs are not getting the same performance is 1) airfoils 2) wingloading . This system has been optimized for max loiter at minimum power
OK, happy with that
If you are happy with the log file, then that is easy enough. It is easy enough.  Will finish the V2 mods and get the log posted here.
Ok Duffy PM me the place and we can do that! A 5.6 amp/h draw is pretty impressive. How long is the hover time in that?
Ah, It all makes sense now. What voltage
How's the 5 hour flight coming along?
Didn't manage to arrange this,
 got some transitions https://youtu.be/kjujvE9UsIE
The specs for the max endurance flying:
 Airspeed: 16 m/s
 Current consumption: 2-5 A (level flight)
 Total Payload : 3.65 Kg (battery inclusive)
 Prop: 20*10 with 2.5o + on hub
 6S , 28,000 mAh battery
 Motor: 5325/16 V2
Of course subject to payload and flying speed and conditions max endurance drops.
Currently designing new wing-tips that based on CFD will provide another 3-6 % gain at minimum power / max Cl
 Best
