Hey all,
Seems I've fried a battery :(
I have the charger and parallel board shown below.  Was planning on charging 3 batteries.  Plugged in the first 2 just fine, but plugging in the 3rd got a 'poof!'  One of the connectors came off the board, and the battery connectors are black'ish now.  One of the connectors from the board broke/melted off into the battery balance connection, so I can't even test the charge now.
What did I do wrong? I used the charger to charge 1 battery successfully.
@Byron,
The damaged fourth XT60 connector on the board appears to be physically reversed on the board compared to the other XT60 connectors on the parallel board. Therefore I suspect that when you connected the battery mating connector to that particular XT60 board connector it caused a reverse polarity voltage to be applied to the battery?
TCIII AVD
I'm such a fool! It was obvious that it was going the opposite way, but I thought "Hey, I know jack s**** about batteries/chargers...so maybe it's supposed to be this way."  It's wasn't, and now I'm wondering why I didn't check the supplier page and see for myself that the connectors should all have been the same way!
-_-
Lesson learned.  Thanks Thomas!
Pretty bad quality control on that board, what is the brand and where did you get it? That's a pretty dangerous mistake for them to make. Must have given you a hell of a fright!
I got it from here:
http://smile.amazon.com/gp/product/B00H98F4ZW/ref=cm_cr_ryp_prd_ttl...
Hahaha it did startle me :p
