Laptop controling viewing FPV and a joystick
I am a Developer/Network Engineer looking to design a VB .net app that can control a airplane little like a flight sim.  Right now I dont want the camera to move around it is going to be static in the cockpit just like a pilot view.  I would also like to keep this under $500 but will go to $700 for the right gear..   Later on I would like to add UAV chip to my setup but for now here is what I am looking at..
What I have so far:
  • USB capture card that imports the live video to VB .net
  • Cheap Camera using 2.4 tx/rx
  • VB.net app will capture the live video and save a wav file
  • VB.net accepting my saitek joystick (usb)
Planning on buying:
What I want or think I need, was hoping for some pointers here:
  • OSD..  This is a must, of some short that is
  • Radio is a big question what radio should i get?  I want a 72MHz
    • Futaba 7CAF 7-Channel $250
    • Spektrum DX7 $299
  • Transmitter Interface
    • PCTx $50 (I am writing my own VB.net App)
    • Milehighwings $40 (emailing them for VB.net support)
  • Upgrade Camera and Wireless
    • Camera CMOS CM-26N $32
    • LM 1000mW 1.2Ghz Combo $135
So what do you think am i looking in the right direction?  By the way once I get the code working I will make it open source for anyone else..
Tuska
  • HI Chris, I am developing a similar project although I capture the video to a standalone screen and DVR. Mine is written in vb2010 but most of it should compile in vb.net, you are welcome to a copy of the source if you like. Although not the best written code it flies okay and there may be some parts of the code you code tear out and use in your project. There is a photo of the old version on my profile page along with a description of what it does and also a video which shows that latency (i.e last second climb over the fence) isn't really an issue so long as your not stunt flying.
    James
    VB.NET Shop
  • I have a remzibi osd if you want , never used.
  • If you don't yet have a radio yet, am I correct in assuming you are not an experienced RC pilot?  If so, then start there first. What you are proposing should work, unless there is a latency issue with the PC end. I would definitely have a safety pilot on the main Tx with your setup going to the trainer input. If you all ready know this then I was wrong. If you have never flown RC and think this my be a way to do it, then you are wrong.
    Hello Tuska,
    Are you thinking about something like this:
    http://www.flytron.com/programmers/56-compufly-usbtoppm-converter.html
    Regards
    Martin
DIY Robocars via Twitter
RT @chr1sa: Our next @DIYRobocars virtual AI car race is next Saturday. Compete from home using the @donkey_car simulator -- no physical ca…
3 hours ago
RT @RoboticMasters: Students from @Sydney_Uni working hard on improvements and changes to @donkey_car simulator. @diyrobocars @adafruit…
3 hours ago
Practice virtual race this Saturday; the real thing will be on Oct 3 https://www.meetup.com/DIYRobocars/
Wednesday
Wednesday
Derrick Davies liked lisa TDrones's profile
Wednesday
Sep 21
RT @SahikaGenc: AWS DeepRacer & Hot Wheels Track https://youtu.be/4H0Ei07RdR4 via @YouTube
Sep 14
Sep 8
RT @davsca1: We are releasing the code of our Fisher Information Field, the first dedicated map for perception-aware planning that is >10x…
Sep 8
RT @SmallpixelCar: How this works: 1)object detection to find cones in single camera image, 30 frames/sec on @NVIDIAEmbedded Xavier. 2)comp…
Sep 8
RT @SmallpixelCar: Use two color cones to guide the robocar. No map needed, on onsite training needed. Just place the cones and it will fol…
Sep 7
Sep 7
RT @roboton_io: Great to see http://roboton.io running at 60fps on the cheapest #chromebook we could find! #edtech #robotics #educat…
Sep 3
RT @openmvcam: Crazy in-depth article about using the OpenMV Cam for Astrophotography: https://github.com/frank26080115/OpemMV-Astrophotography-Gear https://t.co/BPoK9QDEwS
Sep 3
RT @openmvcam: Hi folks, it's finally here! Our first draft of our Arduino Interface Library is out! It works over SoftwareSerial, Hardware…
Sep 3
RT @chr1sa: Please let them have an open API. This would be perfect for @DIYRobocars races https://twitter.com/NintendoAmerica/status/1301513099707658246
Sep 3
