Can anyone give me some pointers on how to build an electric FPV platform with an endurance in the 30-40min range?
The payload should be in the 250-400g range, when the FPV is installed.
I've been looking at the following frames:
http://www.hobbyking.com/hobbyking/store/__27132__Skywalker_X_8_FPV...
http://www.hobbyking.com/hobbyking/store/__27111__Skywalker_1680_V6...
http://www.hobbyking.com/hobbyking/store/__20276__Darkwing_FPV_Dron...
http://www.hobbyking.com/hobbyking/store/__14465__EPP_FPV_1_8M_X_La...
http://www.hobbyking.com/hobbyking/store/__32087__HobbyKing_FPV_UAV...
http://www.hobbyking.com/hobbyking/store/__41322__Hobbyking_Sky_Eye...
Do any of you tried the platforms? Any pros/cons are welcome :)
Thank you in advance.
/Michael
Hi Joe,
The motor I'm using is a Rimfire .32 I had available that supports 3-4S configurations and turns 800 rpm/volt. I think I could probably spend some time improving the cg location to achieve better glide performance without increasing drag. Right now I have a more forward cg location which is great for stability, but may perhaps be increasing the necessary power application to maintain the given speed and to hold altitude.
Nathaniel ~KD2DEY
