  • Thanks Chris! I carefully reviewed both links but unfortunately the are all for the Mega 1280/2560. There is no version there that will work with the Atmega 328.
    I found and old manual fort this board and says that the code was  an ArduPilot 2.3 version. Does someone have copy or link to that source code?
    thanks!
    There is some very ancient code here and here
    Google Code Archive - Long-term storage for Google Code Project Hosting.
  • Greg: it will be of great help if you can get hold of the old source code and send it to me. Thanks in advance
  • Thanks for your response Greg. I have the gps and other stuff. The firmware on the board was replaced by other application and I want to have the board working again for teaching purposes.
  • First I must ask, why bother with one of those. Do you have thermopile sensors or a imu sensor board. I flew one of these a back in those days. Had 3 axis thermopile and GPS and 2 way telemetry. I may still have a copy of the firmware that I modified.
    I still have the hardware and a custom ground station based on the 328.
DIY Robocars via Twitter
Practice virtual race this Saturday; the real thing will be on Oct 3 https://www.meetup.com/DIYRobocars/
Wednesday
Wednesday
Derrick Davies liked lisa TDrones's profile
Wednesday
Monday
RT @SahikaGenc: AWS DeepRacer & Hot Wheels Track https://youtu.be/4H0Ei07RdR4 via @YouTube
Sep 14
Sep 8
RT @davsca1: We are releasing the code of our Fisher Information Field, the first dedicated map for perception-aware planning that is >10x…
Sep 8
RT @SmallpixelCar: How this works: 1)object detection to find cones in single camera image, 30 frames/sec on @NVIDIAEmbedded Xavier. 2)comp…
Sep 8
RT @SmallpixelCar: Use two color cones to guide the robocar. No map needed, on onsite training needed. Just place the cones and it will fol…
Sep 7
Sep 7
RT @roboton_io: Great to see http://roboton.io running at 60fps on the cheapest #chromebook we could find! #edtech #robotics #educat…
Sep 3
RT @openmvcam: Crazy in-depth article about using the OpenMV Cam for Astrophotography: https://github.com/frank26080115/OpemMV-Astrophotography-Gear https://t.co/BPoK9QDEwS
Sep 3
RT @openmvcam: Hi folks, it's finally here! Our first draft of our Arduino Interface Library is out! It works over SoftwareSerial, Hardware…
Sep 3
RT @chr1sa: Please let them have an open API. This would be perfect for @DIYRobocars races https://twitter.com/NintendoAmerica/status/1301513099707658246
Sep 3
RT @SmallpixelCar: Lanenet pretty much used all my GPU power on @NVIDIAEmbedded Xavier since I optimized with tensorRT. I need to run anoth…
Sep 3
RT @LyftLevel5: Our @kaggle competition on Motion Prediction for Autonomous Vehicles is now live! Experiment with the largest-ever self-dri…
Aug 24
