Log files are needed for: Determining Control Parameters Using Artificial Neural Network
Hello all, for a one-week project (deadline is next week) I need a pixhawk flight logs. My aim is that using parameters( RCIN, Altitude, IMU, Desired_Alt and motor outputs) I will try to replicate flight characteristics and input-output correlation.
For this, I need at least 2 flight logs recorded on QuadCopter with pixhawk, which has to contain SERVO 1-4 (motor outputs) and the flight should mostly be in stabilize mode with the same vehicle and same PID settings across the flights.
Any help is appreciated
PS: The flights should be "normal" and "healty" (At least till the end) By saying normal, I meant no flipping or no racing etc.
PS-2: The more the input from different users the better the results, ie I can compare relationship between different frames in different pid settings etc. Thanks again!
Really? Of all the members here who constantly flies their vehicle, no one shares just a few flight logs? Is it that hard to do?
