Lost prop mid flight
Morning,No wind here this morning, did my pre flight check, all was going well then lost my front prop mid flight, the Ardu fell out of the sky from about 8'. I did damage to 2 props a motor and a motor mount, no more flying today.Need to keep getting up, much need flying time required before I put my camera on the Ardu.Hope your all having a good flying day.
  • Kristian,
    I am in the same position.  If I can trust the bird, I can put a camera on it.  I had the same thing happen this weekend.  I am running a hexa and was running fine for about a half hour, then at about 60' alt, it flipped and went into the ground head first.  The prop did not break in-flight, it spun off the top nut.  Now, I am back in the repair business.
    The fact that I was flying around for 30 minutes says that everything was fine, however I don't check prop tightness everytime I land.  My problem with the setup is that 3 of the 6 blades are turning clockwise and all of the threads to tighten the props are tightened with clockwise rotation.  That means that the 3 turning in CCW are not in much danger of coming loose from rotational forces.  The CW props are all in danger of this happening..  I hate to put lock tight on the threads, but maybe that is what I have to do.  I would rather have a CCW tightening top nut on those props.
    Anyone have this issue
DIY Robocars via Twitter
Practice virtual race this Saturday; the real thing will be on Oct 3 https://www.meetup.com/DIYRobocars/
Wednesday
Wednesday
Derrick Davies liked lisa TDrones's profile
Wednesday
Monday
RT @SahikaGenc: AWS DeepRacer & Hot Wheels Track https://youtu.be/4H0Ei07RdR4 via @YouTube
Sep 14
Sep 8
RT @davsca1: We are releasing the code of our Fisher Information Field, the first dedicated map for perception-aware planning that is >10x…
Sep 8
RT @SmallpixelCar: How this works: 1)object detection to find cones in single camera image, 30 frames/sec on @NVIDIAEmbedded Xavier. 2)comp…
Sep 8
RT @SmallpixelCar: Use two color cones to guide the robocar. No map needed, on onsite training needed. Just place the cones and it will fol…
Sep 7
Sep 7
RT @roboton_io: Great to see http://roboton.io running at 60fps on the cheapest #chromebook we could find! #edtech #robotics #educat…
Sep 3
RT @openmvcam: Crazy in-depth article about using the OpenMV Cam for Astrophotography: https://github.com/frank26080115/OpemMV-Astrophotography-Gear https://t.co/BPoK9QDEwS
Sep 3
RT @openmvcam: Hi folks, it's finally here! Our first draft of our Arduino Interface Library is out! It works over SoftwareSerial, Hardware…
Sep 3
RT @chr1sa: Please let them have an open API. This would be perfect for @DIYRobocars races https://twitter.com/NintendoAmerica/status/1301513099707658246
Sep 3
RT @SmallpixelCar: Lanenet pretty much used all my GPU power on @NVIDIAEmbedded Xavier since I optimized with tensorRT. I need to run anoth…
Sep 3
RT @LyftLevel5: Our @kaggle competition on Motion Prediction for Autonomous Vehicles is now live! Experiment with the largest-ever self-dri…
Aug 24
