  • SO i am thinking this. To add a ground plane I could just use a piece of PCB and attach it to the top of my GPS puck. Drill a hole in the center of it and run wire through it. Solder sleeve to ground plane. Is this the correct thinking here?
  • Multipath in the "urban canyon" is a real challenge. A ground plane helps, and there is a setting in U-Centre that limits the minimum angle above the horizon for a satellite to be accepted (I can't remember the specific param, but google probably knows).
  • Awesome post man thanks. I could try and see what it gets. My only question is, while i know a 70mmx70mm square is not that large in cases where size is an issue what then. I could always purchase a reach setup but then again i dont need that level of accuracy. The main thing i am worried about is multipathing and signal loss flyaways due to multipathing because of incorrect positioning. I am planing on doing some flying around some tall buildings, dont want to hit anything or have the quad hit anyone.
  • You could see if adding a ground plane gives the improvement you're after. http://electronics.stackexchange.com/questions/150849/how-big-a-gro...
    I use a disc of single sided pcb as a ground plane, but you could use copper tape, foil, or a pie tin
DIY Robocars via Twitter
Friday
RT @_JonMyer: 🏎 We need your help in naming my #AWS DeepRacer Underground Track 🏎 @davidfsmith's track is going to be referred to as 𝗔𝗪𝗦 𝗗…
Thursday
RT @gclue_akira: 仕事もおわったし、電脳化にとらい #マリオカートハック https://t.co/4IU90hCLgm
Thursday
This is the hashtag to follow all the people in Japan who are hacking the new Nintendo Mario Kart with the real AR… https://twitter.com/i/web/status/1319281354664677376
Thursday
RT @gclue_akira: @chr1sa @diyrobocars jupyter mario https://t.co/P0oHdjlCRq
Thursday
RT @_JonMyer: 🚨Our 1st AWS DeepRacer Community Race is Underway on http://twitch.tv/aws 🚨 Join us to find out which member of your commu…
Tuesday
Oct 19
RT @BackyardRobotcs: After an admittedly long wait, the new Tinymovr R3.3 motor controller is now available https://tinymovr.com 🥳
Oct 19
RT @_JonMyer: 🏎 1 hr left before the #AWS #DeepRacer Community 🏎 Top 5 Race tomorrow LIVE on Twitch 1st Place = $50 Amazon GC or AWS Credit…
Oct 19
Oct 16
Oct 15
Oct 14
RT @davidfsmith: Race virtually with The AWS DeepRacer Community Race and then join us on the track to see how your times compare on the ph…
Oct 14
Oct 14
Hiroki Tanaka liked Hiroki Tanaka's profile
Oct 13
RT @breadcentric: It's now!
Oct 13
