Hi Everyone,
I'm currently using Madgwick's popular filter for my own AHRS project. After some experimentation with sensors and adjusting the beta gain, I've noticed some unpredictable behavior of the filter. For example, euler angles computed from the quaternion changed unexpectedly to 20 degrees off the reference angle (in a static scenario!).
After setting the magnetometer input to (0,0,0) the problem stayed the same. Then I removed the gyroscope inputs (0,0,0) and the problem stayed the same. My conclusion was that it must have been related to the accelerometer inputs.
After experimenting with real sensors I moved to artificial ACC input data and set up a test bed for Madgwick's algorithm (MadgwickTests on GitHub). I've figured out that in Madgwick's algorithm the fast inverse square root leads to huge instabilities when noisy measurements are applied. As an example, consider the pitch and roll angles shown in the following image:
The input for the filter was: gyro = (0,0,0), acc = (2.5, 2.5, 9.15)  +- 0.1 uniform noise (see test.c for details). As you can see, the pitch and roll angles (red/green, in degrees) of the original implementation show unacceptable variations.
Remarkably more stable and accurate pitch/roll angles (blue/magenta) were achieved by exchanging the inverse square root implementation. I used  the following code from Accurate and Fast InvSqrt for computing the inverse square root of float x:
unsigned int i = 0x5F1F1412 - (*(unsigned int*)&x >> 1);
float tmp = *(float*)&i;
float y = tmp * (1.69000231f - 0.714158168f * x * tmp * tmp);
Please see the GitHub commit in which I've added some code for switching between the original (0), the proposed (1) and the reference (2) inverse square root implementations.
I hope that my investigations are helpful to improve the accuracy of Madgwick's C filter implementation.
Cheers, Tobias
No the C code is running on my flight controller which is a PIC32MX.
Maybe an idea to copy the code to the PC en simulated it.
I compared this code:
https://github.com/TobiasSimon/MadgwickTests/blob/master/MadgwickAH...
To this one:
http://www.x-io.co.uk/res/sw/madgwick_algorithm_matlab.zip
in matlab.
And I get very different results with the same sensor data. Still have to double check if I converted the C code correctly to Matlab. I will post some pictures today.
Here the pictures matlab code vs C-code (simulated in matlab)
Blue is Matlab Code
Red is C-Code
Upside Up
Upside Down
In the YAW (lowest graph) you clearly can see the difference, this is exactly the problem I have been having.
The difference could be the InvSqrt function, which does not work on a 64 bit PC. Did you check that you are using 1.0f / sqrtf(x) for computing InvSqrt?
i changed it to 1/sqrt.
i think there is an error in de s0 to s3 formula. I think sebastian forgot some brackets. Have to analyse where the differences are. But the matlab code differs from the C code
Interesting. The sampling rates are also the same? Please keep me updated about your research on this.
Yes sample rate is the same and also the gain, I use one set off sampled sensor data (static) and put them in both codes using matlab.
Im not so good with the math and matrices. hopefully I can find the error (if there is) and than I will mail it to Sebastian to see if he agrees.
I changed the code to:
s0= -_2q2*(2*(q1q3 - q0q2) - ax)    +   _2q1*(2*(q0q1 + q2q3) - ay)   +  -_4bz*q2*(_4bx*(0.5 - q2q2 - q3q3) + _4bz*(q1q3 - q0q2) - mx)   +   (-_4bx*q3+_4bz*q1)*(_4bx*(q1q2 - q0q3) + _4bz*(q0q1 + q2q3) - my)    +   _4bx*q2*(_4bx*(q0q2 + q1q3) + _4bz*(0.5 - q1q1 - q2q2) - mz);
s1= _2q3*(2*(q1q3 - q0q2) - ax) +   _2q0*(2*(q0q1 + q2q3) - ay) +   -4*q1*(2*(0.5 - q1q1 - q2q2) - az)    +   _4bz*q3*(_4bx*(0.5 - q2q2 - q3q3) + _4bz*(q1q3 - q0q2) - mx)   + (_4bx*q2+_4bz*q0)*(_4bx*(q1q2 - q0q3) + _4bz*(q0q1 + q2q3) - my)   +   (_4bx*q3-_8bz*q1)*(_4bx*(q0q2 + q1q3) + _4bz*(0.5 - q1q1 - q2q2) - mz);
s2= -_2q0*(2*(q1q3 - q0q2) - ax)    +     _2q3*(2*(q0q1 + q2q3) - ay)   +   (-4*q2)*(2*(0.5 - q1q1 - q2q2) - az) +   (-_8bx*q2-_4bz*q0)*(_4bx*(0.5 - q2q2 - q3q3) + _4bz*(q1q3 - q0q2) - mx)+(_4bx*q1+_4bz*q3)*(_4bx*(q1q2 - q0q3) + _4bz*(q0q1 + q2q3) - my)+(_4bx*q0-_8bz*q2)*(_4bx*(q0q2 + q1q3) + _4bz*(0.5 - q1q1 - q2q2) - mz);
s3= _2q1*(2*(q1q3 - q0q2) - ax) +   _2q2*(2*(q0q1 + q2q3) - ay)+(-_8bx*q3+_4bz*q1)*(_4bx*(0.5 - q2q2 - q3q3) + _4bz*(q1q3 - q0q2) - mx)+(-_4bx*q0+_4bz*q2)*(_4bx*(q1q2 - q0q3) + _4bz*(q0q1 + q2q3) - my)+(_4bx*q1)*(_4bx*(q0q2 + q1q3) + _4bz*(0.5 - q1q1 - q2q2) - mz);
Which seems to work much better, I think sebastian made some error when converting the matrices to formula form.
I als needed to add _8bx and _8bz to make is work.
But the matlab code vs the new C-code is still not 100% exact, but that is probably because of number rounding.
I will make some pictures and post them here, and also email them to sebastian
In the end it was only the error posted above. The rest seemed to be correct (I made a little mistake which generated different data). The rest of the formulas in the C-code is the same as in the Matlab code.
Jeroen, is it possible to get your working Madgwick code including the corrections you made?
These lines where changed in the code, sebastian emailed me that the code on the website was old and soon will be replaced by a new version.
// Reference direction of Earth's magnetic field
hx = mx * q0q0 - _2q0my * q3 + _2q0mz * q2 + mx * q1q1 + _2q1 * my * q2 + _2q1 * mz * q3 - mx * q2q2 - mx * q3q3;
hy = _2q0mx * q3 + my * q0q0 - _2q0mz * q1 + _2q1mx * q2 - my * q1q1 + my * q2q2 + _2q2 * mz * q3 - my * q3q3;
_2bx = sqrt(hx * hx + hy * hy);
_2bz = -_2q0mx * q2 + _2q0my * q1 + mz * q0q0 + _2q1mx * q3 - mz * q1q1 + _2q2 * my * q3 - mz * q2q2 + mz * q3q3;
_4bx = 2.0f * _2bx;
_4bz = 2.0f * _2bz;
_8bx = 2.0f * _4bx;
_8bz = 2.0f * _4bz;
// Gradient decent algorithm corrective step
s0= -_2q2*(2.0f*(q1q3 - q0q2) - ax)    +   _2q1*(2.0f*(q0q1 + q2q3) - ay)   +  -_4bz*q2*(_4bx*(0.5 - q2q2 - q3q3) + _4bz*(q1q3 - q0q2) - mx)   +   (-_4bx*q3+_4bz*q1)*(_4bx*(q1q2 - q0q3) + _4bz*(q0q1 + q2q3) - my)    +   _4bx*q2*(_4bx*(q0q2 + q1q3) + _4bz*(0.5 - q1q1 - q2q2) - mz);
s1= _2q3*(2.0f*(q1q3 - q0q2) - ax) +   _2q0*(2.0f*(q0q1 + q2q3) - ay) +   -4.0f*q1*(2.0f*(0.5 - q1q1 - q2q2) - az)    +   _4bz*q3*(_4bx*(0.5 - q2q2 - q3q3) + _4bz*(q1q3 - q0q2) - mx)   + (_4bx*q2+_4bz*q0)*(_4bx*(q1q2 - q0q3) + _4bz*(q0q1 + q2q3) - my)   +   (_4bx*q3-_8bz*q1)*(_4bx*(q0q2 + q1q3) + _4bz*(0.5 - q1q1 - q2q2) - mz);
s2= -_2q0*(2.0f*(q1q3 - q0q2) - ax)    +     _2q3*(2.0f*(q0q1 + q2q3) - ay)   +   (-4.0f*q2)*(2.0f*(0.5 - q1q1 - q2q2) - az) +   (-_8bx*q2-_4bz*q0)*(_4bx*(0.5 - q2q2 - q3q3) + _4bz*(q1q3 - q0q2) - mx)+(_4bx*q1+_4bz*q3)*(_4bx*(q1q2 - q0q3) + _4bz*(q0q1 + q2q3) - my)+(_4bx*q0-_8bz*q2)*(_4bx*(q0q2 + q1q3) + _4bz*(0.5 - q1q1 - q2q2) - mz);
s3= _2q1*(2.0f*(q1q3 - q0q2) - ax) +   _2q2*(2.0f*(q0q1 + q2q3) - ay)+(-_8bx*q3+_4bz*q1)*(_4bx*(0.5 - q2q2 - q3q3) + _4bz*(q1q3 - q0q2) - mx)+(-_4bx*q0+_4bz*q2)*(_4bx*(q1q2 - q0q3) + _4bz*(q0q1 + q2q3) - my)+(_4bx*q1)*(_4bx*(q0q2 + q1q3) + _4bz*(0.5 - q1q1 - q2q2) - mz);
Ok, thanks for the information. I will try out the new code once Sebastian has uploaded the new version.
