  • Hi - I had the same problem......  the replacement worked first time !!
    Hope this helps.
    Philip
  • Hi - I had the same problem and cured it by fitting a new mag.  New one worked first time.
    Philip
    Hari,
         Some more information would be helpful.  For example:
                  - which magnetometer you're using (sparkfun or diy drones)?
                 -  how have you connected the mag?  directly to the oilpan or via a cable?
                 - if you're using the sparkfun mag I hope you're using a level converter (as suggested on the wiki).
                 - if you're using a cable have you correctly plugged it into the "no gps" port?
                 - have you checked that all the soldering is ok?
                 - have you crashed recently?
         Anyway, as mentioned on another thread, you're not getting values back from the mag so it's likely a wiring problem or a fried mag.
