I have just completed my implementation of of using the MAVLink XML to setup decom tables to process the MAVLink 1.0 stream.  In the process of checking out the decom process I noticed that Messige ID 25 is not properly populated.   Looking at the attached file 07201700.lis  which is a hex dump of some message ID 25 frames you will see that fields satellite_prn, satellite_used, and satellite_elevation are not properly populated.  Fields satellite_azimuth and sattellite_snr are suspect,  The attached file 25.lis is an excerpt from the MAVLink header file defining message ID 25.  I checked it and it matches the MAVLink XML message definition.  This message ID is useful in determining the geometry of the GPS fix.
Thanks,
Warren
Hi Seth,
Sorry for late response, pls give me some time to extract the Mavlink proc from a bigger project.
Hieu.
Hieu,
Nice to hear that, can't wait to see.
Seth
