Has anyone used the mini telemaster before as a UAV platform? How did it perform? Are there any other planes within this price range ($150-240) that are better then the telemaster?
Thanks!
Sam
I have--nice little platform, if pricey. It's better with the aileron wings.
In general foam planes are better for UAV training, given the likelyhood of crashes. The only case for balsa is more interior room. Any reason you don't want to go with the standard EasyStar?
I was hoping for the more-roomy interior. how much weight could the EasyStar hold? What modifications could I do to it to hold more?
Are you just starting with RC and UAVs? If so, something that's crash-resistant like the EasyStar is a lot more important than interior room. If you're an experience RC pilot and cost is no object, the the mini telemaster is fine. The EasyStar can carry everything we need, including HD cameras, autopilots, loads of wireless gear, etc, but the mini telemaster does have more room inside (although it's not as easy to keep the payload centered on the CG.)
Two other choices which are similar and in the price range are the Alpha 40 electric and the NexStar Mini EP.
Foam does have durability advantages, especially if you are a poor RC pilot, but traditional balsa planes do have a big advantage that Chris did not mention. They fly faster, which makes navigation, particularly in wind, much easier.
If you are interested in interior room and capacity, but like the durability of the Easystar, then check out the Skywalker (best current deal is at BEVRC.com, I think).
BEVRC.com no longer exist....but I found it on http://www.fpvflying.com/categories/FPV-UAV-RC-modelplanes/ Is this what you were talking about?
Sam R.
take a look at the new multiplex fun cub. I just got one and am building it up. It has lots of nice pockets for gear lots of room. It has ailerons,flaps, 55 inch wing, 40 oz stock weight should be real stable and its multiplex epp. It's goes for $120. I will know how it flies in a couple of days. hobby people has it on sale for $99. it evan has a tow release and realy big weels that will handel any surface and breaks down very nicely for transport
Cool. Yah, please keep me posted on how it flies. Is it flying with or without a payload?
Thanks,
Sam
Wooh. It cost $99 for just the kit, without any of the electronics. You need to buy the battery, charger and electronics kit for it separately. Then what does it come to?
Sam
It will add up quickly. I all ready have the electronics.
Samuel,
You-may-want-to-consider-stock-wings-such-as-EasyStar-(TowerHobby)
or-Radian-(ParkZone)-with-3-stick-(triple-boom)-fuselage-and-1/4-in-foam-tailplane-(Lowes).
http://www.rcgroups.com/forums/member.php?u=128179
http://www.rcgroups.com/forums/showthread.php?t=1300632
John
Please-pardon-the”-“
myspacebarbitthedust
My first real plane was a mini-Telemaster. 47" and about 3.5 lbs full up weight. It flew beautifully.
Some observations on how it flies:
- It is too light to avoid nosing over, when taking off and landing on grass. You will have a lot of bent motor shafts.
- It is very light for flying in any wind. A 5lb plane will be a lot more stable.
- A bigger plane will also have more fuselage room, for putting in cameras.
- You'll need wheels about 3" big to roll on grass.
or mount the landing gear on the motor firewall - if your converting to electric you need new gear anyway so larger wheels and really far forward gear mount works well.
