hey guys,
Well, i am working on a project using apm2.8 ardupilot, and i need to make a live transmission video using MinimOSD. I have found the code on DIYDRONES repository on github, but it seems that its not up to date with the version of Arduino IDE, so i need to know with wich version this code will compile.
I have tried version( 1.67/1.6.6/1.6.5/1.6.4/1.6.3/1.6.0/1.0.5) without any success
In my case, i need to edit the code of MinimOSD
While compiling the code in Arduino IDE, i get error.. it depends on the version of the arduino platform ..
For example, for the arduino version 1.6.7(latest version), i get an error in "FastSerial" library:
"error must include fastserial.h before the arduino serial driver is defined with minimosd"
I have tried several version of Arduino, they all had a compile error.
-The code is provided on Github:
https://github.com/machaalany/MinimOSD-Extra/tree/master/MinimOsd-E...
-And the libraries are:
https://github.com/machaalany/MinimOSD-Extra/tree/master/librariesOK
--> can you please let me know with wich version of Arduino this code should compile ? I am in very need for this code to compile because i need to make some modifications
elie
It compiles fine on arduino 1.6.5-r5 , and some older.  , nothing newer that that.
Yes, it's "Fastserial" that is the problem, I can't even get in touch with it's author.
AFAIK , it was once it was used for "non-blocking" serial write. The Arduino serial library have been improved , and I would still like to have a good programmer to answer the simple question: "is fastserial giving us any advantage over the usual serial or softwareserial library ?"
nobody seems to know...
Hi
I just compiled with 1.0.5 . Is not a problem with the version. I had some problem with the libraries
I did my personal relase , changed  the altitude information and used to understand the mavlink messages
I  used  AC3.2.1 so  i did chekout from the  official repository:
"git clone -b ArduCopter-3.2.1 https://github.com/diydrones/ardupilot.git --single-branch ArduCopter-3.2.1"
Open the folder with librariesOK and copy it in your Arduino program path
..\Documents\GitHub\MinimOSD-Extra\librariesOK
In the Arduino go in preference and  write the path  (In my case i use git in windows )
...\Documents\GitHub\MinimOSD-Extra\MinimOsd-Extra_Copter
This is the result , hope will be useful
http://diydrones.com/profiles/blogs/ac3-2-1-default-streamrate-chan...
thank you for your help mate, finally it compile :D .. do you know if this code will work with ether Apm 2.8 and Pixhawk ? version wont be a problem ?
it works with anything that outputs Mavlink 1.0 , that's any recent ArduPilot project.
okey mate thanks alot :)
Btw, loading the code into OSD will be enough for its to work properly and to display data on screen right  ?
nothing else is needed ?
I am using Arduino 1.0 + Visual Studio + VisualMicro plugin. I have heavily modified MinimOSD though, removed tons of stuff I don't need, added flight time estimation, added internal settings screen instead of additional panes.
I used minimOSD-extra + librariesOK as a base.
thank you for your reply konstantin !
Well you said Visual Studio + VisualMicro plugin .. can i know how ? and to modify what does the screen display, i should modify the arduino code? or the Visual Studio/VisualMicro plugin code ?
Please explain as much as you can
regards
You can look at my repo: https://github.com/kosmikkosmik/apm-osd - it contains Visual Studio solution. Basically there is both Arduino and C++ code, I just used to work with C++ that's why the code I've added is in C++ rather than Arduino stuff.
Just install:
* Visual Studio Community Edition (it's free for personal use)
* Arduino 1.0
* Visual Micro
okey mate thank you for your help :)
Dear Domenico,
Thank You very much for your how to file, this is actually what i want get in last one week. I want to get invole in mininosd coding so i get fully customized on this.But very hard to get starting point for me.
Just now, i do fast read on your how to file, still didn't get 100% understanding on it, but I will read it again and again. I hope I can get future help from you to get smoothly on minimosd coding.
Thank You again,
