I have problem to set up MinimOSD together with telemetry system on APM board.
- APM 3.0
- MinimOSD 0.1v
- Boscam Aerial camera
- Boscam 5.8G Diversity Receiver 7.0 Inch TFT LCD Monitor
- Boscam 5.8 200mw 8channels FPV Wireless Transmitter
Wiring diagram that I used:
http://www.rcgroups.com/forums/showthread.php?t=1810347
From time to time I get short signal but suddenly it disappears. Telemetry works fine over “Y” cable.
Thanks!
Check you video output. PAL or NTSC. I had the same issue and and when I set the output of the camera to NTSC it solved my problem. Hope this helps.
