Mission Planner 1.2.50+ on Ubuntu Linux with mono
Newer versions of Mission Planner  (1.2.50+ iirc) need some additional mono packages to work on Ubuntu. They're only available in Ubuntu Precise 12.04 and above though. You can install them like this:
sudo apt-get install -y mono-runtime libmono-winforms2.0-cil libmono-corlib2.0-cil libmono-system-web4.0-cil libmono-system-management4.0-cil
If you have problems seeing the serial ports, make sure you're in the dialout group:
sudo gpasswd --add $USER dialout
(you'll need to log out and back in again to be sure any group changes take effect)
  • Hi Meine,
    While updating, after editing repo, it says:
    Err https://launchpad.net precise/main amd64 Packages
    Err https://launchpad.net precise/main i386 Packages
    Ign https://launchpad.net precise/main Translation-en_US
    Fetched 3,161 kB in 9s (329 kB/s)
    W: GPG error: http://download.opensuse.org ./ Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 8984BBB839EBCBCA
    W: Failed to fetch https://launchpad.net/~borgdylan/+archive/ppa/dists/precise/main/so...
    W: Failed to fetch https://launchpad.net/~borgdylan/+archive/ppa/dists/precise/main/bi...
    Could you type the command that you used to edit the repo?
    Launchpad
  • Good morning,
    I running 1.2.76 with additional packages and the add $user without problems.
    However, today MP ask to update and installed 1.2.80.
    After this upgrade I couldn't start MP again. Mono failed with mono MissionPlanner.exe': No such file or directory.
    I reinstalled 1.2.76 and all working fine.
    any Idea what could be wrong???
    thanks
    Dieter
    just do a
    sudo apt-get install -y mono-complete
