Whats up with the airport overlays, I can not find how to turn it off and it just clogs up the screen and blocks views.
I don't know about your.. but all i see is a bunch of numbers scrolling on startup.. like NAV COORDINATES.
No one has an answer how to get it off the screen????? or no one uses this version.
I have updated and wished i can go back a version...
i don't see what you see...
i see the stuff loading in the console..
i double click the screen and it stops and just loads.. but crashes alot.
There's a check box on the planner options page where you can turn these off.
Hello Scott. You referring to the console checkbox? That does
not do the trick.
In Mission Planner under the Config/Tuning tab you will find, "show airports". Uncheck the box & this should remove all that mess.
