Mission Planner 1.3.39 Dataflash log auto analysis broken
I just installed the update to MP 1.3.39 and realized that the Dataflash auto analysis is broken.
.bin files I could auto-analyze in the previous version of MP result in a "Failed to start LogAnalyzer" followed by a bad input file message wit this release.
I attached one of my .bin files in question
Any insights?
Not silly at all as it IS a 32 bit program and is installed into the x86 area where x86 programs are installed. The program calls on functions though that are OS controlled and the OS can call on more than 2 gigs of memory.  And yes it is related :) And it comes down to the core function of the OS and how it, for lack of a better word, partitions memory and gives access to memory requests,
Jeremy Randle said:
This might be a silly question, but I note that my copy of Mission Planner is installed in the /Programs Files (x86) directory. For some reason I had it in my mind that this is where 32 bit versions of programs were typically installed. Is this correct ?
I also note that that the Auto Analysis seems to fail on larger files. Could they be related ?
If so, how do I get a 64 bit version of Mission Planner, or is the program the same and the discussion is solely about whether Windows is 64 Bit ?
mp will run fine on x86 (joystick support requires this), the log analyzer will only run on x64 (due to memory issues).
x86/32bit only supports 2gb of memory, and the analyzer uses a lot of memory.
if you install python yourself you MAY be able to run the log analyzer however.
My computer runs an Intel Xeon E5-2630, 16Gb RAM and Windows 7 Pro 64Bit. The Auto Analysis fails on a 50Mb log from around a 25 min flight, with some non flying time before hand. Just tried it again and it killed MP, causing it to close.
1) Is it best to run this on the BIN or the LOG as it seems to convert the BIN to a LOG before it can start anyway ?
2) Is there anything I can do to make this work, or are the flights just to long ?
can you zip/rar the log and attach it to a reply so we can take a look at it?
I just zipped it up and it is 22MB which is more than the 7MB limit. Should I put it on CloudStore or similar and post the link here ?
anywhere that is publicly accessible really.
The file is uploaded here. Thanks for looking in to this.
https://cloudstor.aarnet.edu.au/plus/index.php/s/VPYOKkgDsDgoXA4
Takes a while but it opens fine on my box
Log File C:\Users\Craig\AppData\Local\Temp\tmpAC67.tmp.log
Size (kb) 110111.673828125
No of lines 1438418
Duration 0:20:11
Vehicletype ArduPlane
Firmware Version V3.5.2
Firmware Hash dc9d87fd
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Autotune = NA -
Test: Balance/Twist = NA -
Test: Brownout = GOOD -
Test: Compass = GOOD - mag_field interference within limits (11.23%)
Max mag field length (703.92) > recommended (550.00)
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = GOOD -
Test: GPS = GOOD -
Test: IMU Mismatch = GOOD - (Mismatch: 0.58, WARN: 0.75, FAIL: 1.50)
Test: Parameters = GOOD -
Test: PM = NA -
Test: Pitch/Roll = NA -
Test: Thrust = NA -
Test: VCC = GOOD -
I have had problems for months trying to auto-analyze data flash logs on MP, to the point of giving up. I run Windows 7 on a 64 bit Sony VAIO. I tried again yesterday using latest ArduPlane and latest MP and it failed yet again. Short session, smallish log file.
Kelly
What is the error reported and maybe attach the logs here so we can see if we can reproduce the error.
oh you said plane. sigh. no experience with the plane firmware but other do so maybe still do it.
Kelly
Michael,
I checked the release notes - I could not find any statements that the Auto Analyze function is all of a sudden no longer supported on x86 machines with version 1.3.39. I would appreciate if you could look into this - since it was working fine all the time before with the previous MP versions this should not be such big of a deal. Its certainly harder for us to purchase new hardware w/o prior notice....
Thanks!
@michael oborne I just upgraded to the 1.3.40 release and can report that Auto Analysis works fine again on Win32/x86.
Thanks for fixing this!
