@Michael O
From THIS conversation,
Would it be possible for you to put human friendly times accross the top of the dataflash graphs? Please leave the line numbers there.
While I am at it , could you please make it so that when you move your mouse cursor across the graph, the tip of the cursor displays a crosshair accross the comple witdh and height of the graph, to make it easier to read of line numbers and values..
thanx!
Wessie
change your font size in control panel back to normal (100%)
Thanks, that solved the problem.
Three items:
When a heartbeat is not received after 'x' seconds, Mission Planner would try to reconnect using a different protocol (from a user-defined list).
Mission Planner sets a flag when the program is first booted, and loads all parameters when it CONNECTs, then clears the flag and stores the SYSID.  After that, if a re-connect is requested and the flag is cleared and the SYSID has not changed, MP would not download all parameters.  This goes with my first request and would prevent a complete reload of parameters after redundant communication had been established.
Another protocol - SSH, should be added to tcp, udp and udpcl.   The use of SSH adds security to the connection without going through a proxy or dealing with port forwarding.
And also a command-line startup of MP where i at least can wait for UDP 14550 and fullscreen :)
Gentlemen, this is a very old list. Feature requests are now being tracked at https://github.com/ArduPilot/MissionPlanner/issues?q=is%3Aopen+is%3...
Please repost.
Thank you
