I've got a question about Python Scripts in the Mission Planner:
I want to send waypoints to my Arducopter with a Python Script. I already found this page: http://code.google.com/p/arducopter/wiki/Python.
Unfortunately there is no information about how I can send whole waypoints to the quadrocopter.
I would be glad if someone would have an answer!
Tags:
hi,
anyone here succeeded in sending waypoints using python in the mission planner?
thanx
I can't get this code to work...
First I got the error of there being no "ArdupilotMega", so I swapped it with "MissionPlanner" and that error went away. Then I got the error that "Locationwp undefined", so I added in "from MissionPlanner.Utilities import *" and instead used "item = Utilities.Locationwp()" and that previous error transformed into "Error running script attribute 'Locationwp' of 'namespace#' object is read-only"
So, do you have an updated script that will perform the functions you detailed above??? THANKS!!
Hi Joe,
I had the same problems but now it works. Try this:
import clr
import MissionPlanner
clr.AddReference("MissionPlanner.Utilities")
item = MissionPlanner.Utilities.Locationwp()
MissionPlanner.Utilities.Locationwp.lat.SetValue(item,lat)
MissionPlanner.Utilities.Locationwp.lng.SetValue(item,lng)
MissionPlanner.Utilities.Locationwp.alt.SetValue(item,alt)
Does that help you?
hi,
I also tried this, nothing seems to happen - no error, but no waypoint either...
any ideas? do you need to specify the new waypoint #?
That does help, thank you! I no longer get errors on trying to set the waypoints... however, I cannot verify that the APM 2.5 is actually receiving the commands & executing them because I have neither an airframe, nor HIL capability. =/
Also, I'm now getting the error when trying to set the mode to "RTL" at the end of the script. Here's my script:
import sys
import clr
import time
import MissionPlanner #import *
clr.AddReference("MissionPlanner.Utilities") # from MissionPlanner.Utilities import *
print 'Starting Mission'
item = MissionPlanner.Utilities.Locationwp() # item = Utilities.Locationwp()
lat = 39.343674
lng = -86.029741
alt = 45.720000
print 'WP 1 set'
MAV.setGuidedModeWP(item)
print 'Going to WP 1'
time.sleep(15)
print 'Ready for next WP'
lat = 39.345358
lng = -86.029054
alt = 76.199999
print 'WP 2 set'
print 'Going to WP 2'
time.sleep(15)
lat = 39.342106
lng = -86.031371
alt = 53.340000
print 'WP 3 set'
print 'Going to WP 3'
time.sleep(15)
lat = 39.343540
lng = -86.028732
alt = 53.199999
print 'WP 4 set'
print 'Going to WP 4'
time.sleep(15)
print 'Mission Complete'
MAV.setMode(RETURN_TO_LAUNCH)
#Script.ChangeMode(RETURN_TO_LAUNCH)
print 'Returning to Launch'
And here's the error message I get when the script reaches the final command to change the mode to "RTL":
"Error running script name 'RETURN_TO_LAUNCH' is not defined"
Any idea on the proper syntax to change the mode at the end of the script??
I think I got the mode change at the end to work now, too... I was missing the double quotation marks inside the ChangeMode function so python was treating RTL as a variable instead of an literal argument being passed...
I think this will work:
Script.ChangeMode("RTL")
I did... here's the script that worked for me in using ArduPlane (which should work for ArduCopter too):
import sys
import clr
import time
clr.AddReference("MissionPlanner.Utilities") # includes the Utilities class
time.sleep(10) # wait 10 seconds before starting
Script.ChangeMode("Guided") # changes mode to "Guided"
print 'Guided Mode'
item = MissionPlanner.Utilities.Locationwp() # creating waypoint
lat = 39.343674 # Latitude value
lng = -86.029741 # Longitude value
alt = 45.720000 # altitude value
MissionPlanner.Utilities.Locationwp.lat.SetValue(item,lat) # sets latitude
MissionPlanner.Utilities.Locationwp.lng.SetValue(item,lng) # sets longitude
MissionPlanner.Utilities.Locationwp.alt.SetValue(item,alt) # sets altitude
print 'WP 1 set'
MAV.setGuidedModeWP(item) # tells UAV "go to" the set lat/long @ alt
lat = 39.345358
lng = -86.029054
alt = 76.199999
print 'WP 2 set'
time.sleep(10)
lat = 39.342106
lng = -86.031371
alt = 53.340000
print 'WP 3 set'
time.sleep(10)
lat = 39.343540
lng = -86.028732
alt = 53.199999
print 'WP 4 set'
time.sleep(10)
#MAV.setMode(RETURN_TO_LAUNCH)
Script.ChangeMode("RTL") # Return to Launch point
time.sleep(10)
Script.ChangeMode("LOITER") # switch to "LOITER" mode
print 'LOITERING'
Note: this is a TIME-based script... it will guide the UAV to the next waypoint after waiting a specified amount of time. One would have to replace the "time.sleep(10)" lines with "Script.WaitFor('ARMING MOTORS',30000)" [and replace 'ARMING MOTORS' with whatever notification Mission Planner usually provides upon arriving to a waypoint] to replicate the mission plan creation (i.e., go to next waypoint after arriving at previous waypoint).
Hope this helps!
Wow ... the pythonscriptoption in mission planner is more helpful than I thought.
But were this new commands come from? MissionPlanner.Utilities.dll?
Is it possible to execute the "do_digicam_control" command via python?
I cant tel lyou the exact command, but something like
MAV.doCommand((MAVLink.MAV_CMD.DO_DIGICAM_CONTROL, 0, 0, 0, 0, 0, 0, 0);
should work
while im at it
MAV.doARM(true);
MAV.doReboot(false);
MAV.setWPCurrent(1);
MAV.GetParam("PARAMNAME");
MAV.setParam("PARM",1.0);
MAV.getWPCount();
MAV.getWP(1);
to list a few
thanks for your reply, but i cant get it work
the MAV.doCommand needs 8 arguments and "MAV_CMD" is expected, that is what i find out.
But no matter how I write it, I get an error "not defined"
I just found a website that might be helpful to me:
I do not get it to run :(
I would like to extend the lens from my camera automatically in "AUTOmode
and retract the lens when i return in STABILIZEmode
I use CAM_DURATION(MissionPlanner) and get_usb_power(CHDK) to communicate between APM and camera.
MissionPlannerscript:
while True:
if cs.mode == 'STABILIZE' and Script.GetParam('CAM_DURATION') == 2 :
Script.ChangeParam('CAM_DURATION',1)
if cs.mode == 'Auto' and Script.GetParam('CAM_DURATION') == 1 :
Script.ChangeParam('CAM_DURATION',2)
CHDKscript:
@title Cam
print "Script Started, Listening"
sleep 1000
goto "interval"
:interval
p = get_usb_power
m = get_mode
print m
if p > 5 and p < 15 and m = 0 then set_record 0
if p > 15 and p < 25 and m = 1 then set_record 1
if p > 15 and p < 25 and m = 0 then shoot
goto "interval"
with "Trigger Camera Now" it works already.
But i need a possibility to trigger the cam in the pythonscript
after I've searched for days in the source code, I have found what I was looking for.
the command MAV.setDigicamControl(1) can trigger the camera via pythonscript.
So I have full control over CHDK with a cheap USB cable like this: http://diydrones.com/profiles/blogs/apm-to-chdk-camera-link-tutorial
The pythonscript change the CAM_DURATION(the time the trigger is pressed),
CHDK count how long the trigger is pressed and depending on it do what you want.
In my case the lens moves out if i switch to AUTO and retracts if i in STABILIZE MODE.
Pythonscript:
while True:
CHDKscript:
@title Cam
sleep 1000
goto "interval"
:interval
p = get_usb_power
m = get_mode
print m
goto "interval"
the query "p >and p <" is because "p" varies a little bit
another possibility would be the objective retract if you fall below a certain height,
too adjust the zoom factor via the height or remotecontrol
or whatever ...
Thanks for your help Michael Oborne
45 members
1472 members
282 members
470 members
57 members
Powered by
