Can I monitor the voltage of a secondary LiPo and then trigger a PWM output if the battery reaches a predetermined voltage? I was planning on using this from Matek. It has a PWM on/off switch. I'm guessing I can watch the voltage with some sort of I2C voltage monitor. I believe Christian Mauch has such a device. Thanks!
  • I found this module which appears to provide voltage via I2C. Now, how do I make use of it? Thanks!
