Hi My problem is this my aircraft flies in Manual, Stabalised or FBWA, if I switch to Auto, RTL or Cruise the motor stops, I have GPS lock, the Compass is fine, anybody got any Ideas Regards Geoff
Hi Graham Forgot to load these files Regards Geoff
2015-10-31 09-32-34.tlog
2015-10-31 11-23-45.tlog
Hi Graham Dyer, I have not been able to find an answer to the problem, but have found another, I have 3 other aircraft 2 of which fly missions with no problem, a Phantom wing and HK EPP both have APM 2.5 boards, the 3rd is a Bixiler 2 which last time flew a mission some 3 months ago, but now is doing the same thing, to these 3, I fit the same GPS unit, I have been able to sort out the log file and some graphs and attached them, maybe you can view them and find a problem (NAV_ROLL seems to change big time when switching to different Automatic modes) Regards Geoff
2015-10-31 Bixiler 1.txt
2015-10-31 Cloud Fly.txt
Post a log.
Those modes are GPS dependent so perhaps there is something wrong with altitude.
Hi Graham Thanks for your reply, firstly I don't no how to post or look at a log, the model is on the bench, not flying, I have looked at mission planner, It shows me at 310m abs, which I know is right, the home default alt is set at100m,and 7 satilites are registered, the model goes through the prearm check and shows no errors and then arms no problems pulling the throttle to the lower left corner, if you look at the fail safe screen the RH collums drop to zero when the 3 switch positions are selected. Regards Geoff
