As the title says my job is to fit the parrot sequoia into the 3dr's gimbal for the solo. Parrot made the sequoia to the same dimensions of a gropro for 'effortless' swapping in and out of already produced gimbals. The only issue, the gorpro has a connection on the back that goes up into it. The sequoia does not have a connector or open space to fit over it properly. Keeping the gimbal working properly and not off balanced or off balanced enough so that a counterweight could fix it. How can I modify the mount to get a good secure and working fit for the sequoia to the 3dr solo gimbal for the GoPro?
Thanks for your help!
