Need Help For Crash Log File Analysis
Hi All,
My quadcopter suddenly fall down after 50 seconds.
Before the fall I flew 3 minutes successfully at Alt Hold mode.
After crash I measured battery and it showed 23.74V but at flight log CURRENT:Volt value is 21.71Volt at last log row. Before the flight battery module was calibrated.
Thanks for any help.
My Quad specs;
Arm length motor to motor : 80cm
AUW : 3.7kg
Battery: Tattu 16A 6S
Motors : T-Motor Mn4010 - 370KV
ESC: T-Motor S35A 600Hz with SimonK
Gps: 3DR ublox gps
Telemtry: 3DR 433Mhz
Fligth Controller: Pixhawk
Power Module: Dshot® APM 2.5.2 2.6 Current Sensor Power Module
15-05-05_19-10-22_1.log
  • Your log ends midair.All signs points towards pixhawk being suddently shutdown, (brownout) the CURR.Vcc variation during flight is not *too much* or dangerous in any way, but it did vary between 5.099v and 5.175 flight, and 5.22 during flight.  , I think it's"interesting" that the last  CURR.Vcc record shows 50.90v (the lowest one, only recorded once before during the flight)
    While voltage above 4.2v will not brownout a Pixhawk,  , any temporary drop below 4.1 will cause reboot.  , but remember that power is logged at 1Hz, and that's a lot of time in the terms of electronics, so much else could have happened.
    Did you had power redundancy ? (did you power it using the DF13-6 power connector *and* had power applied to USB or Servo rail ? )   - and : were the extra power between 4.5 and 5.7v ?   - this is important - because 6v on servo rail would *not* be connected thru the power management chip if primary power failed.
    • 50.90v should, of couse , be "5.9v" :)
      • Thanks Andre,
        I am using standart 6-pos DF13 cable with Dshot® Power Module because it supports 6S battery.
        No power applied to USB or Servo rail. No extra power.
        Is it normal last logged 21.71 Volt battery voltage?
        Because I measured battery and it showed 23.74 Volt after crash.
        Best Regards.
        • Yes, your battery voltage is fine, it's normal to be lower under load, and even 21v/6cells=3.5vcellvoltage , no reason to crash, besides,even if the battery were depleted, you'd expect Pixhawk logging until impact.
          Wrote from my phone, if admins of this site don't fix the outdated google login, I'll be gone as my browsers cookies expire.
          • Hi,
            It could be voltage sag problem?
            Best Regards.
            • As an electronics engineer, I do not know that "voltage sag" is  - apparently some people invented that phrase without explaining which technical term it was supposed to represent :)
              If you think about a voltage drop due to high internal resistance of battery,  or wiring resistance - while under heavy load,  yes, voltage may drop under load, (your log did not have a aggressive climb in the moments before)  but before your main battery drops to way below 4.8v (which pixhawk needs)  it will not affect the flight controller.
              If you think voltage from your (only) 5v regulator dropped, below ~4.8,  yes, that's most likely scenario for a brownout and reboot, or just shutdown, the question is why it dropped, bad connection, was it too weak and a thermal protection kicked in etc..
              • Thanks Again.
                I am learning a lot of things.
                Battery Fail Safe voltage was 22.4 Volt. Last seen voltage value is 21.x volt.
                Could It be activated?If It was actviated Could We see it at logs?
                It is seen a connection problem I think.
                Stupied me :)
                • Most likely a faulty connection, yes.
                  Failsafe was not trigged, but that would never give such result anyway.
                  For some reason your log does not contain FS_BATT_ENABLE or FS_BATT_VOLTAGE , so it's impossible to say.
DIY Robocars via Twitter
RT @_JonMyer: 🚨Attention DeepRacer's including #UndergroundDeepRacer🚨 Check our our LIVE stream that including @IAM_dbro Take a few moments…
Aug 5
DIY Drones via Twitter
RT @MarvelmindMaxim: Extreme precision for 60 swarming robots. #marvelmind #autonomousrobotics #robotics #swarmrobotics #rtls #ips #indoor…
Aug 3
RT @MarvelmindMaxim: Precise (±2cm) tracking for racing boats and autonomous boats. Works outdoor and indoor. #autonomous #AutonomousVehic…
Aug 3
RT @MarvelmindMaxim: Helping PixHawk folks to fly autonomous quadcopters using PX4 and ArduPilot. https://marvelmind.com/drones/ Equally suitab…
Aug 3
RT @chr1sa: The @DIYRobocars @donkey_car virtual AI car race is starting in 15 minutes! Watch it live on Twitch https://www.twitch.tv/mossmann3333 htt…
Aug 1
RT @chr1sa: Don't miss our monthly @DIYRobocars @donkey_car virtual AI car race tomorrow at 10:00am PT live on Twitch. Head-to-head racing…
Jul 31
RT @sparkfun: Our completed tutorial on building an @NVIDIA Jetson Nano-powered @Sphero RVR gets your bot up and running via teleoperation…
Jul 30
RT @SmallpixelCar: Freeway test https://t.co/4V5tV9lhIP
Jul 29
Very small autonomous cars racing, thanks to an overhead camera: https://control.ee.ethz.ch/research/team-projects/autonomous-rc-car-racing.html
Jul 29
Jul 29
Jul 29
RT @chr1sa: Don't miss our virtual AI car race this Saturday! Real developers + virtual cars =🏎️🏎️🏎️ Head-to-head battles with thrills, sp…
Jul 28
Jul 27
RT @usashirou1: Jetson nano by Isaac Kaya #jetson https://t.co/Mu1N0CyQkN
Jul 23
RT @GPUsolution: JetRacer mady by Iflytek company #JetsonNANO #Nvidia https://t.co/MimTymIwge
Jul 23
RT @openmvcam: I love this: Mega or Mini? Image Classification on the 1MB OpenMV Cam H7 by Ish Ot Jr. in OpenMV, Edge Impulse, Internet of…
Jul 23
